Question about Craftsman Garden
Garden tractor shuts down when you PTO on or release brake
I have a craftsman garden tractor,model 917276051.The eng.is ok but when I put the pto. on or release brake clutch Eng.will shut down.can you help.
  • 437 Answers
You have a safety switch or a relay malfunctioning. Try going to www.partsdirect.com, this is sears website. Look at the diagram to see how many safety switch on this unit. You may get lucky and replace one or you may have to replace all. I would look to see if it has a safety relay first, try replacing that first.
Posted on Sep 30, 2009
  • 4 Answers
Sounds to me like there is a problem with one of the safety switches. My wont mow in reverse and shuts off when i get off the mower. All designed to prevent accidents. I would check those.
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
My craftsman ZTS 6000 dies when I take the parking brake off. It has just started doing this. Which part do I replace?
It is most likely the driver presence switch located under the seat. If the tractor has the brake set it will start and run without the driver in the seat. (PTO-off)
Releasing the brake requires a driver of sufficient weight to be in the seat for the tractor to continue to run. If the switch is defective the tractor even with driver inplace will stall. The PTO (mower deck must not be engaged).
Hope this helps?
Oct 30, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
DLT 2000 48" Deck 20 Hp. Starts but when you lift the brake or engage the PTO IT TURNS OFF... Have already replaced the PTO still have the same problem. Model no. 917.272246 Help...
this one id look at the operators seat switch , maybe its not working like it should
seat switch's verify that operator is present in seat , like if you hit a bump and fell off it , it should shut down engine -so tractor is less likely to run you over
Oct 01, 2015 | Craftsman Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Ignition acting funky
With many of these Tractors, as part of the safety B.S., much of the electronics run through the PTO switch. Power to the ignition runs through the PTO.
Jan 04, 2014 | Craftsman Garden
Craftsman lawn tractor will not run if i engage the pto. will run with brake pedal pushed but, when i release presure on brake it shuts off? Can lock the brake and get off runs fine.
This is a micro switch issue, more than likly the switch under the seat or the connection block onto the switch is not fully pushed on.
Jan 09, 2013 | Craftsman Garden
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
When the PTO switch is engaged the motor shuts down the same thing happens when the clutch is let out . I have replaced all the safety switches once before and that solved the problem. I replaced the PTO...
Be sure to check the back end of the seat switch wiring for loose or shorted wires. If the engine is shutting off when the brake pedal is released or the pto is engaged most likely the seat switch has failed. The seat switch connector has a shunt built into it. If the connector is not firmly plugged on the seat switch, it grounds out and when the clutch is released or the deck is engaged, the engine will die. Look closely at the connector and you will see a plunger that is pushed in when it is plugged on the seat switch. If the connector is on the seat switch securely, either the seat switch or the connector might be shorted internally. You need a meter to test this. The seat switch should read open when pushed. I hope this is helpful.
Aug 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
126 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
