Question about Cameras
I'm not able to download pictures from My Sandisk SDHC 4 mb card with my camera anymore, because the camera has an lenserror. With an external reader I can get no connection either, so the question is: how can I get acces to my pictures????
    Brigadier General:
  • 3,006 Answers
Have you checked that the external reader is definitely SDHC compatible?
I've encountered a few which have a slot labelled with every variation of the SD/MMC format but which have proven not to be SDHC compliant. Generally these have been the cheapest unbranded readers or on branded (counterfeit?) readers from unreliable sources.
If this is not the case then you either have an SDHC card with corrupted data or a faulty card. Corrupted data can usually be recovered with data recovery tools, but all you can do with a faulty card is to ensure that the terminals are clean and to try it in another reader.
Posted on Oct 21, 2009
What program do I need to download my photos from my Sandisk Ultra 16gb SDHC Card
Is your card reader compatible with SDHC cards? While the card will fit into an SD-compatible card reader, it will not work unless the card reader was designed to be SDHC-compatible as well.
Nov 15, 2013 | Samsung SanDisk Ultra SDHC 16GB High...
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
I put a sd memory card from my camera in my computer. the computer hasnt uploaded the pictures or done anything.
I guess you have a built in card reader? Is there any chance your camera SD card is SDHC? Some card readers including built in types and those that you connect to a USB port have trouble with the later and faster generation SDHC cards but are happy with plain old SD cards.
If you are using an external card reader, does it work in another computer? If it does work, then the problem is with your computer.
If you have a built in reader, can you borrow someones external card reader that you know and does work with SD and SDHC cards?
Can you try an older SD card in your current setup? If that works OK then it's the issue with SDHC that is your problem.
Easily fixed by buying yourself a $10-20 external card reader
Cheers,
Steve
Aug 11, 2010 | Computers & Internet
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Just got a SanDisk 4gb SDHC card. Put it in my camera took some pics and my card reader doesn't work with it. Works with other cards (not SanDisks) The only way it will work is if I plug my USB cable...
Upgrade your card reader.
SDHC cards are a very different animal under the skin to a standard SD card and so they're not back compatible with plain SD card readers (although SD cards can be used in SDHC devices).
May 05, 2010 | SanDisk 4 GB Memory Stick PRO Duo Card...
Need to know what memory card can i purchase and where for kodak easy share c530 my camera is old haven't used much I have a 1.0gb sandisk can i use a 2gb sandisk.
I had a look and it seems 1GB is about the Maximum? yes Sandisk is a good brand. Frankly anything that works well is OK.
Buy a good brand of card ... SanDisk is my favorite.
Kodak would certainly be a good choice too.
Don't buy it on eBay, as there are too many counterfeit cards available on eBay.
A Tip:
If you use a card reader, you will need a SDHC card reader if you use a SDHC card.
Most older card readers can not read a SDHC card.
Tip number 2:
Always format a new card with the Camera before taking any pictures.
You will find how to format with the camera in the camera User Manual.
Feb 05, 2010 | Kodak EasyShare C315 Digital Camera
Is lumix dmc-fx33 compatible with sandisk ultraII 8gb sdhc cards?
No, 8 GB is too large. According to page 5 of the manual, 4 GB is maximum:
•When the term card is used in these
operating instructions this refers to the
following types of Memory Cards.
– SD Memory Card (8 MB to 2 GB)
– SDHC Memory Card (4 GB)
–MultiMediaCard (still pictures only)
More specific information about memory
cards that can be used with this unit.
• You can only use an SDHC Memory Card
if using cards with 4 GB or more capacity.
• A 4 GB Memory Card without an SDHC
logo is not based on the SD Standard and
will not work in this product.
The manual can be had below:
http://service.us.panasonic.com/OPERMANPDF/DMCFX33.pdf
Oct 05, 2009 | Cameras
Card reader in camera or computor wont read sdhc cards
Although my SanDisk compactFlash cards 128 MB 256MB 4GB and 8GB cards are far from being full, when I open up my Canon Powershot A40, the follwing msg appears: CF card full. However, the original Canon Compactflash card FC 8M provided with my camera will still accept new photos. The problem is recent. Can someone help me.
Sep 13, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
I bought two 4 GB PNY Optima SD HC 60 HD cards for my Canon PowerShot SD 800 IS Digital Elph for a very special event. It captured all of the photos as my other cards have, but when I went to download the...
pny does not supply card readers w/memory cards-sandisk on certain cards includes reader because file format is different on sdhc cards -try downloading direct from camera w/usb or get a card reader that absolutley supports sdhc type cards-not all readers do!
Jun 25, 2008 | Cameras
Cameras Logo
97 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
