Question about Refrigerators
My Frigidaire refrigerator single inlet valve Model GLHS66EFSB3 which is three years old is leaking. This valve is green color. I do not know how to take it off without taking the double inlet valve of as it has been mounted on one piece of fixture.
This part failed on 4 of the 10 homes in my CDS. There is a class action suit getting started. We all had flooded basements because of the failure. $90 part, unbolt it and replace it and call the company for a refund....
Posted on Nov 15, 2009
How do you check the water solenoid for proper operation
Refrigerator Not Making Ice? How to Test a Water Inlet Valve
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
Click here to purchase a replacement refrigerator water inlet valve: .... +Benoit Hamel Low water pressure could cause the valve not to close properly too.. Read more ... I do have an audible feature and it does beep when I check it that way ... My Maytag refrigerator water dispenser/ ice maker not working.
Fridge Water Inlet Valve Replacement - Frigidaire ...
? 2:26
https://www.youtube.com/watch?v=1J3VDTbiAvA
Apr 26, 2011 - Uploaded by RepairClinic.com
Fridge Water Inlet Valve Replacement - Frigidaire Refrigerator ...the refrigerator is leaking water, or the water dispenser is notworking. ... Check out our blog: http://www. ... +spaz376 If you do not use the dishwasher it is recommended you disconnect the power. .... Local repair said it may be the solenoid?
Dec 14, 2015 | Refrigerators
The ice dispenser works but the water dispenser does not
6404d9bc-b69f-4578-bd32-49c46ecf9312.jpgHaving a water line freeze in the door is possible but the most likely reason for not getting the dispenser to work is a defective=> WR57X10070 Water Inlet Valve on the dispenser side of the water inlet valve. I would like you to watch the video and if you have questions let me know Thanks Sea Breeze
Apr 30, 2013 | General Electric GE Profile CounterTop...
The water in the ice maker freezes solid instead of cubes; some of the spray overshoots into the bin. As a result the metal spiral turning fork gets jammed and comes out of its slot.
Hi and welome to FixYa. I am Kelly.
You are experiencing an inlet water valve water bypass symptom. What is happening is that the inlet water valve is allowing water to drip into the ice maker after the harvest cycle has long since finished. This is a common failure and all brands of refrigerator that are more than 5 years old. Replacing the inlet water valve will correct the over-fill problem. (I actually had to do this on my own 8 year old Maytag refrigerator not 6 months ago.) If you provide a model number I can point you to several on line sources for the inlet water valve.
Or you can just enter your model number on the following links:
http://www.frigidaire.com/productregistration (enter your model number)
http://www.searspartsdirect.com/partsdirect/index.action (Use the "Find it fast" window in "Model; search")
http://www.repairclinic.com/Shop-For-Parts (enter your model number in the search window)
If you do not have an inline water filter I would recommend that you install one at the time you replace the inlet water valve. It will keep plumbing debris out of the now inlet water valve and ensure a longer service life for same.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water leaks from dispenser
Bad water filter or weak water inlet solenoid. Water line to back of fridge goes to inlet solenoid valve. Check it first. Would help to know the manufacture date. If it has a filter at bottom of fridge it will cause leaks and low pressure to dispenser if not changed each year.
Sep 11, 2009 | Refrigerators
No ice are water
MOST OFF THE WATER VALVES ARE DAUL WATER VALVES . CHECK THE OUT LET OFF THE WATER VALVES . IF YOU HAVE WATER IN AND POWER . AND NO WATER OUT YOU HAVE A BAD WATER VALVE
Feb 04, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker leaks
soundslike the water valve is notcompletly shutting off, causing a slow drip try replacing the water inlet valve behind hte unit where the water installs to the refrig
Nov 20, 2008 | Amana ACD2232HR Side by Side Refrigerator
Frigidaire Side by side Leaking water from Behind the dispensor
You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
Apr 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Three way solenoid valve
All you can do is replace the part. I am not sure on frigidaire parts, they use to have 1 year warranty on replacement, some companies have gone to 90 days.
Jan 07, 2008 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
