Question about Linksys Wireless-G WRT54G Router
Wireless g router trouble no conectivity
When i go to the internet it says it has no connectivity or limited but when i connect it direct it works
  • 329 Answers
Connect router directly to computer and go to command promt
at command promt type
c:\ipconfig
look for gateway. it should be 192.168.1.1
if its so
now open internet explorer type ther in 192.168.1.1
it wil ask for user name and password enter admin as user name and admin as password
now locate for ip address..it should be the same as192.168.1.1 change it to 192.168.0.1 and save and reboot it will take a min or two.......now disconnect and connect the router with DSL router. there are five ports in wireless router out of which four for networking and one for internet. put the cable in the internet port and the other end in the internet router after a while internet led on wireless router will get stable.....now start surfing......
Posted on Sep 30, 2009
  • 4,281 Answers
You have to enable DHCP in your wi fi router.
For that connect your wi fi router to youe computer with ethernet cable.
Then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then Enable DHCP.
Then save settings and exit router.
Also check your wi fi network adapter property Check TCP /IP settings enable ip get automatically.
Then it works fine.
Let me know if you need more assistance.
Thanks.
Why is limited internet connection?
You are facing the limited internet connection only when its secured with the username an password.
Check for it or contact your ISP.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
May 01, 2013 | Linksys WRT54G-TM Wireless Router
Can't connect my blu=ray dvd to my wireless internet
Please clarify your model number. If you have the DMP-BD60, it only has wired networking capabilities. A USB wi-fi dongle will not work (the USB port is only for storage devices). If you are connecting it to a wired port on a wireless bridge (switch) or directly to your wireless router and having trouble with the connection, check your cables and that your network is up. Next check that you have not restricted the number of devices allowed to connect to the router. There are ways to limit the number of IP addresses in the router setup. If you allowed 4 addresses and the blu-ray player will be number 5, you need to adjust the settings for your router.
Please add a comment with the model number if you are using a different blu-ray player. I hope this helps.
May 05, 2012 | Televison & Video
Why my d-link wireless limited access all user who want to conecting my network..including my.eventhough i have a key security?
if you don't have internet on the connection, it will tell all connected that access is limited.
Otherwise they are using the wrong key or encryption. I'd need more information about the wireless to help (key type (wep/wpa) etc.
Mar 08, 2011 | D-Link DI 514 Wireless Router (DI-514)
CAN'T SEEM TO CONECT TO MY WPN824 NETGEAR ROUTER WIRELESSLY WORKS FINE IF I CONNECT STREIGHT INTO THE BACK WITHETHERNET BUT TOTALY GOES IF I DISCONECT IT ?????
For the computer/laptop to connect to the wireless router, the wireless card in the computer/laptop needs to be configured with the netgear's wireless settings eg. SSID and encryption etc.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2010 | NetGear RangeMax WPN824 Router
Cannot connect to my Netgear WRG614 v6 Router. My Dell laptop shows an excellent connection but it says limited or no conectivity? I have tried several suggestions and reseting several times...nothing...
If you are using LAN cable from your ISP. Try to connect it to your Computer LAN port directly or how you connect directly your internet connection from your computer without the router. Then on your system tray try to look the internet icon activity usually a two monitor icon. Right click on there. Then select status,then support, then details, from there see the DNS number you may get two DNS numbers set then put that manually to your wireless lan settings.
Jun 06, 2009 | Computers & Internet
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Wireless rounter
in your address bar type 192.168.1.1 and go into your admin screen. if you have password type it in. Go to wireless tab and look up your security settings
Dec 05, 2008 | Linksys Wireless-G WRT54G Router
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Internet connection
try to update the router's firmware to the latest one, if conection is still dropping try lowering the MTU size(by default its set to auto) to 1492, 1480, 1472, 1450 check which MTU size will make you connection stable.
Aug 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hooking up without a modem
how to you get online through the wireless connection? Did you put a username and password or a static ip address?
Aug 03, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys Wireless-G WRT54G Router Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
