Question about Pioneer DEH-P80MP CD Player
ACC line error
This does not happen when i crank my radio all the way up on the radio. but when i put it a CD and try to crank the volume i get to right about 42-44 and then it says ACC line error... does any1 know what i have to do to fix this? or if i culdve installed soemthing wrong
  • 1 more comment
  • Anonymous Apr 26, 2008
    I have the same problem with my deh-p80mp. Somekind power source problem maybe?
  • mcmikeyb Apr 26, 2008
    I have the same issue as well. It used to work absolutely fine in my old Astra, but now I've put it in my BMW 318i it complains when I run it anywhere past 40 on the volume. I'm running it in 60W mode and I'm thinking it's one of two things - the in-car speakers can't handle it or it's trying to draw more power from the ACC line than is possible. I removed the extra cable saying 'When using this unit at 60W setting, connect ONLY to ACC line of 10A or more.' Any ideas?!
  • g_haughton81 May 06, 2009
    i cant turn up my music while playing a cd the error in acc line always comes up so i cant use no options
Your stereo is trying to pull more juice then your electrical system wants to dedicate to the accessory line. Thats why Pioneer provides a secondary source wire that is attached to the inline fuse. Mkae sure that the fuse is no more than 10A as the larger fuse will provide too much resistance. Another problem that could be happening is that many auto manufacturers(foreign especially) have gone with lower voltage wiring harnesses. Use a multi-meter and make sure that you are getting a minimum of 12-14volts constant with key in the on position. If voltage is reading 9-10 volts which is common in some model cars, you may have to upgrade your system or just live with 3/4 volume. Good luck guys.
Posted on Jul 04, 2008
My key is stuck in the ignition.
Your car has several different ignition positions. They each offer slightly different functionality.
Off: In this position, the engine is off, and so are your electronic accessories (unless the delay has not expired yet). You can still turn on lights (headlights, interior lights, etc.).
ACC: This is the accessory position. Turn the key to ACC if you want to listen to the radio, play a CD or use other accessories without cranking the engine.
On: In this position, all of the electronics should come on. This is also the position that the key will return to after cranking the engine.
Start: Turn the key to this position to crank the engine. Let go of the key when the engine is running and the key will return to the on position.
http://www.aa1car.com/library/ignition_switch_positions.jpg
I use to own a car that had an ignition that was ACC - OFF - ON - START.
Try turning your ignition one position clockwise and see if the radio turns off and the key comes out.
https://hackadaycom.files.wordpress.com/2008/08/ignition.jpg?w=450&h=338
Jan 29, 2017 | Cars & Trucks
My samsung sch R380 freeform says can't get volume. what do i do to fix that
if you can open your phone and test your ******** and speaker if it works
Sep 06, 2012 | Samsung Sch R380 Freeform Iii - Black...
Cd player doesnt work and states ''error 06''
If you all ready try cleaning the CD lens now the next step is disconnecting the negative wire from the car battery for about 10 min. but make sure that you have the radio code before disconnect the battery or make sure that your radio does not have a security code, if nothing happen after this try you must send the radio for repair usually they have to replace de CD lens. Good luck
Jan 02, 2010 | Car Audio & Video
Wiring hookup for 6 disc cd changer
battery would go to battery and acc. should go to the same wire that is marked acc. on the back of the radio. this is the accessories wire.
Jun 12, 2009 | Pioneer CDX-FM687 6-Disc CD Changer
HI,I INSTALLED MY DEH-6500 PIONEER RADIO,CAME ON DEMO MODE,PUT CD IN VOLUME WORKS BUT CANT CHANGE SONG ON CD,TOOK CD OUT,BACK TO DEMO MODE WHERE I CANT DO ANYTHING,CAN YOU HELP GET ME OUT OF DEMO MODE...
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
Notes
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 26, 2009 | Car Audio & Video
I dont no what i do whit the acc and what is my line i put in the power or the ground i dont have the plan for the truck and the radio
Use a voltmeter (VOM) to find 12v wire always ON, this connects to the receivers YELLOW wire. Then use the VOM to find a 12v wire ON with Ignition, this will connect to the RED wire on your unit, Then use the OHM function on the VOM to find a suitable GROUND, this will connect to the BLACK wire on your unit. The ACC wire is for activating a power antenna.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 12, 2009 | Pioneer DEH-P2900MP CD Receiver...
Need to crank the volume to hear XM Radio
Defently take it back to get fixed it shouldn't work that way. it should be the same or louder when your deck is set to 20 for the volume
Jan 01, 2008 | XM Radio (XMP6000)
Can't go past 40 volume with Cd in
Check to see if the selector switch in rear of unit is switched to 60. if that is the case, then your speakers are not capable of handling the power. This is a safeguard Pioneer has built in to the unit. It senses the wattage allowances and self adjusts to the allowed wattage of the speakers. If this is the case, then you need to upgrade your speakers.
Nov 28, 2007 | Pioneer DEH-P80MP CD Player
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Pioneer DEH-P80MP CD Player Logo
801 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
