I was just given a sony kp51ws500 tv however they told me the color wheel is broken and the picture is green im looking for the part number for the new color wheel and how hard it is to replace
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
KP-51WS500 IS a rear projection set and does not have a color wheel
I suspect you may need to adjust the green screen control---if you do not know how to attempt this let me know and I will post the instructions here for you.
I am here to help people
SD TECH
Posted on Sep 30, 2009
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony TV Model No. KP51WS500 flashes green & turns off
yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
Apr 08, 2010 | Sony KP-51WS500 51" Rear Projection...
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony KP-57WS500
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Convergence out; having problems realligining red lines
Check all six small,soldered in pico fuses under IC heatsinks..
rated at 3.15 amp = do not exceed.............let me know.....T.
Nov 27, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
