Question about Magellan Meridian Gold GPS Receiver
How do you set waypoints on the Magellan Meridian gold. To and from a location?
Press and hold the GOTO button for 2 seconds. A "Mark" screen will appear. If you are saving your current location, highlight the "Save" at bottom of screen and press enter. This will save you current location. You can edit the name of the waypoint at this screen also. You can do this before you save the waypoint or you can go to Menu/Database/User/Waypoint (the one you want to edit)/Enter. At this screen you can edit the name by pressing the arrow up or down to get to the name field and press "enter" to get to the alphabet screen. If you are entering a waypoint using coordinates, do the above but edit the coordinates to the ones you want to use and then save.
Posted on Oct 07, 2009
My Magellan Meridian Gold GPS works with a car cradle but does not power up with its own battery power. How can I fix my receiver to work with its batteries?
You may find the problem is with the connections from the battery to the circuit board.
Take the back off and check the battery connectors where they contact the board. They may need cleaning or re aligning
Mar 10, 2010 | Magellan Meridian Gold GPS Receiver
My Meridian Gold GPSr won't find our location. The
You might try leaving the batteries out of the GPS for a few days and then put them back in and set back up GPS. I know Garmin has a download for the loss of satellites on some of their GPS's but not sure if Magellan does or not. I have set up several of the Meridian Golds and have never had any issues with them.
Dec 03, 2009 | Magellan Meridian Gold GPS Receiver
Where can I get a users manual?
http://www.magellangps.com/assets/manuals/Meridian_series_en.pdf
May 18, 2009 | Magellan Meridian Gold GPS Receiver
My magellan meridian gold does not turn on ,,and if it does the screen is all blue
The unit is coming on but the LCD display has Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} separated and needs replaced.
Apr 23, 2009 | Magellan Meridian Gold GPS Receiver
Need instruction manual for meridian color magellan p/n 800482-01
Yahoo's user group called Magellan_Meridian has manuals and great information on all models.
Dec 04, 2008 | Magellan Meridian Gold GPS Receiver
Magellan meridian gold comes on, won't go past collecting information
If your GPS has been OFF for a long time, and you turn in ON somewhat more than 200 miles from where it thinks it is, then it might have trouble seeing the satellites it thinks it should see.
First check to see that the unit is set to the current time, if it's off by more than a couple minutes then set it as close as you can, see below. Then set the approximate location, you can do this using the unit to select a nearby city.
If the unit, on the otherhand, has been used successfully alot for a long time, then it could have what's called BADRTCR bad realtime counter error. This also means that the displayed time is off from WWV shortwave, or other NIST time references, and it will have a hard time acquiring satellites if you move your GPS while it's trying to do that. You might have to do a [menu] [setup] [clear memory] [all] operation, but save all your waypoints and tracks.
Oct 04, 2008 | Magellan Meridian Gold GPS Receiver
I unscrewed the 6 screws holding the back to the Meridian Gold unit and looked at the contacts. I noticed that one of the curved prongs that makes contact from the battery to the unit was bent low so I knew it was not making contact and preventing the unit from working. So I very gently took the small screwdriver and pulled it out a bit so that contact was the same height as the other. Screwed the back back on, reinstalled the batteries, presto - works like a charm now. Anyone can do it.
Now I need someone to tell me what alternative GPS map packages giv e the most bang for the buck as my Map Send CDs were accidently thrown out by a well meaning person cleaning up my desk....
Jun 12, 2007 | Magellan Meridian Gold GPS Receiver
Magellan Meridian Gold GPS Receiver Logo
838 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
