Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman furnace blower runs continuously
Have a Coleman Evcon Propane unit and the blower runs continuously (and combustion blower). I have done the following.
-Disconnected thermostat wiring.
-Check function of both limit switches.
-Centrifugal switch on combustion blower working.
-Gas valve working.
-Not sure about glow igniter. Reads resistance. Circuit board sending about 2V. Doesn't heat up.
-Circuit board LED indicates no problem (continuous).
Any ideas or other checks?
Thanks
Russ
Only way to make blower stop is to turn off power.
  • 4 more comments
  • BillyGunn Jan 18, 2008
    I have the problem with my Coleman Evcon furnace and like Rusty went thru the same diognostic test and still can't find the problem. Any answers?
  • Bob Meinholz
    Bob Meinholz Nov 07, 2008
    I too like Rusy and Billy Have this same problem and I have gone through the extensive diagnostics that Rusty has. Let me add the main blower will cycle (shut down when up to temp) for a couple of seconds and then restart again but never completely shuts off or cycles like it shoud.(Yes I thought High/low limit switches the same way and both test good). Is this problem in that circuit board somewhere or ????????? Let me know I've been chasing this one for over a month now and the hours on that motor are piling up.
  • benazlin Dec 06, 2008
    I have a similar problem. I've just replaced the circuit board on my coleman model #BRCS0241BB with a retrofit. It didn't come with a diagram, of course. I got the heater to work, but when it hits the setpoint the gas shuts off, like its supposed to do, but the fan keeps running. It'll blink 4 times, which is supposed to be open limit switch. I bypassed that switch and the same thing happens. I'm at my wits end. Any suggestions?
  • tart5 Dec 09, 2008
    have the same problem,mine is still under warenty should i just insist that thay replace it.
  • Anonymous Dec 18, 2008
    I too have the same problem as Rusty, Billy, and the other two. Have replaced the limit switches to no avail. (My furnace in not fuled by propane) Please help!
  • Anonymous Mar 26, 2014
    I have a travel trailer furnace that was working properly until I changed the propane tank and now it will not ignite. the thermostat is working, the blower comes on but no heat.
  • 1,420 Answers
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman combustion air switch failed to close
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Nov 24, 2010 | Coleman Propane Forced Air Heater...
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Coleman Evcon furnace, blower runs continuously even after the temp has been reached.
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
Dec 16, 2008 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
1,243 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
