Question about Olympus Stylus 710 Digital Camera
I need to change the iso setting i think when i take a picture its all blurry and cant see the picture
Nixon S8100 fairly new camera, nice pics if the subject doesnt move but horrible pictures if object moves. Very blurry.
If everything in the picture is blurry, you are moving the camera when you press the shutter button. If only the subject is blurry and the background is clear the problem is too slow shutter speed. If this is cause by movement of the camera you must learn to SQUEESE the button while being sure you don't move the camera. It just takes a little practice. If this problem caused by a shutter speed that is too slow, it is remedied by increasing the ISO "film" speed. Even though you have no film, the camera has a "speed" setting that relates to that. The higher ISO value increases the camera's sensitivity to light and thus allows for faster shutter speed. Normally the ISO choices are 100, 200, 400, 800, 1600. Try using 400. The ISO setting is in one of your camera menus. 400 is fast enough to solve your problem in all but very fast movement of either the camera or subject. Using ISO above 400 will cause your pictures to look grainy and not as sharp. Use the highest speed only when absolutely necessary. Slower ISO numbers produce the finest grain and thus the sharpest pictures. It a trade off between ISO and shutter speed because the exposure is a combination of the ISO and shutter speed and lens opening. Each one effects the exposure by half or double.
Apr 16, 2011 | Nikon Cameras
Randomly, many of my photos are blurry.....
Looking at this camera manual I see that you can switch to PASM mode which I'm suggesting you use "P" Program. Also to get the best ( steadiest) photo's switch to the EFV (electronic viewfinder) there is a little swich just below and to the right of the viewfinder for switch from and too. it may have LCD/EFV on the switch A great idea for the very best photo to print is to use ISO 100 but this may prove difficult in some lighting situations try it and if you have some problems this can be changed to ISO 200 or higher but the higher the ISO number the grainier the pictures will become.
So a reap. Change to "P" program in the PASM mode. Switch to the EFV viewfinder, try ISO 100 but ISO 200 will work as well. What the big change is, is to use the Electronic viewfinder this brings the camera closer to your face and your arms are tucked into your body making it much more stable to hold. Happy New Year
Dec 31, 2010 | Kodak EasyShare Z740 Digital Camera
Pictures are all grainy and blurry. At first all pictures were great but now they are all out of focus and grainy. I don't think any settings were changed but am not sure.
Most likely causes:
The camera was dropped or damaged.
Flash is turned off when it is needed.
Lens is dirty.
ISO setting set to high.
Best bet is to take it to a camera store and let a professional check it out.
If this helps please vote for my solution.
Nov 27, 2009 | Nikon COOLPIX L20 Digital Camera
Blurry action pictures
The sport setting uses a faster shutter speed to stop motion. However, if you have the ISO set to a low number and try to take action shots in dim light, they will be blurry. Either use auto ISO or use a higher number such as 400 or 800.
Sep 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
FUZZY & BLURRY PICTURES.
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
Mar 28, 2009 | Kodak EasyShare Z1015 IS Digital Camera
Digital camera
you can try and adjust the contrast for that pictures. try also iso 300 for the picture to increase quality. downpoint is its size will increase. just explore the settings and try them all out. im sure you will find the perfect settings that you'll like
hope this helps.
fixya!
Jan 31, 2008 | Cameras
Trying to take pictures in low light conditions inside a theater.
when you use high ISO like 800-1600 it will create big novice on image, and when you using law ISO it will be dark for sure.
so the solution is switch cam to TV mode and put into very law shutter speed and use ISO 200-400,make sure you are connected to tripod or else you will not get fine results with law shutter speed. point is when you use law shutter speed camera will take more light to censor even with law ISO your images will be perfect.
Dec 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Blurry pictures
Check to see what the setting is for Image Size (I have sony cybershot DSC-w50). On the camera itself, it is the button on the bottom. My camera was on the 8"x10" size and I was getting blurry shots (especially with people in them). I switched it to the 4x6 print size and it seems to be much clearer.
Nov 24, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Blurry pictures
You're both right. The pictures are blurry because the shutter speed is too slow, but it's too slow because there isn't enough light for it to be faster. Try this: Set the ISO to 800 Set the camera at shutter priority mode, and enter 1/160 for wide angle to mid-zoom, and 1/400 for full zoom. If the pictures come out too dark ( and you're too far to use the flash ), you can always brighten them on the computer. But if they're blurry, you can't really fix that.
Sep 11, 2005 | Olympus Camedia C-700 Ultra Zoom Digital...
Olympus Stylus 710 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
