Question about Dymo Labelmanager 220P Printer
My DYMO Label maker is stuck on the extra small font and wont change. Is it broken?
beachin
  • 6 Answers
SOURCE: Fonts too small
Your instruction manual will tell you. However, there's a "Code" button that has to be pressed at the same time as the "Font" button. (Code button color should match the color of the Font button.) Keep pressing as it cycles through the font sizes (you'll see the arrow move on the screen). When you get to the font size you want, release the buttons and you're good to go!
Posted on Jun 25, 2008
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
  • 2976 Answers
SOURCE: How do I change the tape in my dymo QX50 label maker?
Where the cartridge has a hole in it, make sure the tape is IN the print head, not over or under it. Also, check the type & color of the tape. They have some strange combinations that are only visible under certain conditions.
Posted on May 23, 2009
cns assoc
  • 677 Answers
SOURCE: NEED INSTRUCTIONS ON HOW TO OPERATE DYMO LABEL
Found on WEB
http://static.fixya.com/Manuals/D/Dymo/LtrTg_QX50_T_F0D7A12F6AFDB0376043F6C9CD5E15F9.pdf
Posted on Nov 12, 2009
  • 43 Answers
SOURCE: I need an operators manual for DYMO Letra Tag, is
Click on the big PDF icon on this page to download the manual : LetragTAG
Posted on May 23, 2010
Enlarge font dymo handheld labeler
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see dymo.com for numbers).
^CM
Nov 18, 2013 | Dymo Labelmanager Lm 160 Handheld
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
Jun 22, 2011 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
How do you change the font and size on a dymo letratag?
Aside from changing the size, printing as big or small and using symbols, the LetraTAG does not offer various fonts. This model is pretty basic and has the one font and that is all.
The manual can be found at this location:
http://www.dymo.com/media/UserGuides/QX50US.pdf
May 16, 2011 | Dymo LetraTAG Thermal Label Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
I have a LabelMaker 450D and I do not know how to make the font a smaller size. I want to print a label that has a name in a larger size and a line underneath with the job title that is in a smaller size...
Hello. Here is a free downloadable manual for your labelmaker. http://www.dymo.com/media/UserGuides/LM450D_US_931764.pdf
Turn to pages 9-12 to learn how to change fonts and how to do multiple fonts and underlining all at once.
The label maker remembers the last feature
selection made so that each time you enter one of the
feature menus described in this section, you are
positioned at the last item selected from that menu. J.
Aug 07, 2010 | Office Equipment & Supplies
May 22, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Font size
You can download the manual for the Labelpoint 200 here:
http://www.dymo-label-printers.co.uk/DYMO-LabelPoint-200.html
It describes how to change font sizes and all the other printer functions.
(but briefly: press the 'size' button, use the cursor keys to select the size and press enter. There are only 2 sizes (small and normal) but these can be combined with 3 widths)
Jan 25, 2009 | Dymo LabelPOINT 200 Thermal Printer
Fonts too small
Jun 25, 2008 | Dymo LabelMANAGER 350 Thermal Printer
Dymo Labelmanager 220P Printer Logo
79 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
