Turns on and makes noise but drum dosent move what is wrong . the drum wont move to wash or anything.
    Genius:
  • 1,036 Answers
Check that the drum is free to move - by rotaiing it by hand. If it rotates very freely - it is likely you need a new drive belt. If the drum is very stiff - and won't move, it is possibly a faulty rear bearing. If both these checks are not the problem, it could be a motor or control board fault. It can be a cheap set of brushes needed for the motor - or a new control board.
It really needs investigation to identify which part is needed before replaements are ordered.
Turn off and unplug before investigating further.
Posted on Sep 30, 2009
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
How to disassemble drum from shaft of cw6000w model
my washer agitator will not move or make its usual half turns it makes loud noise i went out and bought a new bas for it tryed it no luck went to take spline off offdrum to fix gaskets or whatever just to check wont come off
Dec 09, 2012 | Crosley CW6000 Front Load Washer
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
Has been working as usual until today .Scuffing/ scraping noises when drum is turning
Check for pin, or other item caught in a hole in the tub rubbing on the outer tub to make noise as the tub turns.
Feb 22, 2011 | Washing Machines
My neptune washers drum wont move could it be a belt the cycles seem to work but after it fills or after it has removed the water it just sits there and the drum dosent move
it could be a belt but in that case you would still hear the motor running if not then the gear box is locked and will need to be repplaced
May 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
