Question about Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range
Gas Viking range: VGRT3624QSS four yrs. old. Constant ignitor clicking when using any burner. You can utilize cooktop but clicking is constant and annoying.
  • 42 Answers
Check if burners are burning ok,if correct one of the spark electrodes is faulty.
Posted on Sep 30, 2009
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
Ignitor is constant even when lit.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jun 24, 2010 | Jenn-Air JGA8100A Gas Cooktop
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
How do I correct the constant click from the electronic ignition which is occuring on three of my 6 burners
Hi, you probably got water under the cooktop while cleaning around the knobs. It causes a short at the 120 volt igniter switches on the shaft of each valve. Unplug the stove for 1 or 2 day and let it dry. By the way, when one sparks, usually they all spark.
Jan 16, 2010 | Viking VGSC366-6B Gas Kitchen Range
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking stove cooktop
Service came out and said just unplug the cooktop and plug it back in. It won't fix it but it will work for.... beats paying 100's of dollars. I wish I knew this to save 85 $. I am going to replace it if this happens alot but until then I going to give it a try for a few times.
Viking has a major problem with this, read other posts. the service guy said alot less problems with wolf and thermador. I will never buy viking again, my cooktop is 2 yrs old with just general household use
Feb 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Open Questions:
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Logo
376 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
