Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water won't stop running even when we turn the machine off it slows a little. i have to turn the water off to stop the flow of water.
  • 4,070 Answers
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Sep 30, 2009
Refrigerator is louder when it turns on maytag performa side by side model psd262lheb
sometimes, as the machine starts to get a little age on them, the Freon flowing through the unit will get a little loud during the first minute or so of cycling on and for about a minute after unit cycles off. could make banging sounds, popping sounds even might sounds like water running or rain. All those sounds are normal operational sounds. I would not worry about those sounds unless you start to notice a slow temp. increase in the next few months. If you start to notice cooling issues, then I would start to get concerned about a sealed system issue.
Feb 26, 2015 | Maytag Washing Machines
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Coffee water won't flow
You probably have hard water deposits in the tubing. Run a couple tanks of vinegar through the machine on a brew cycle. Then flush with a couple tanks of water.
Aug 16, 2012 | Mr. Coffee Bvmcejx33
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
Fills with water and then stops and beeps and won;t continue. The hot and cold water buttons are flashing. Waterr starts trickling in and it is slowly spinning but doesn't seem to agitate
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine fills up only half way....water eners very slow....afta machine stops, I get a PF 6 reading
Try removing each inlet hose in turn and check for water flow from each hose. If seem slow, try reversing that hose to back-flow the inlet filter screen which should remove loose debris, but won't affect any hard water deposits (soak the screen end in white vinegar and hot water for an hour or so). If both hoses flow well, check the entry holes in the machine for plugged screens. If all else fails, replace the twin inlet solenoids. Hope this helps!
Feb 01, 2010 | Amana ALW480DA Top Load Washer
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
I can not get espresso from the coffe nozzle
Without the portafilter can you get just water from the grouphead. If yes check the grind on the grinder make it a little coarser. Think of your coffee grinds as sand and rocks: if you try to run water through rocks it will flow really fast, and if you run it through sand it will flow really slow.
Jan 10, 2009 | Wega Mininova EPU Espresso Machine
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
106 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
