Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
The heater starts but stops after a short time (about 10 to 20 seconds) and the controller flashes repeatadly between C2 then 11. Please respond to Bill at billgatz@comcast.net
    Champion:
  • 248 Answers
Fan, overheat stat
Posted on Oct 15, 2009
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Bosch 22e ys2439r fault 14 , (pcb 1 long flash and 4 short flashes ) cannot get unit to work , i've tryied replacing the pcb,gas valve w. solinoids ,thermistors...etc the fan will kick in for a second but...
No I cannot help fix your tankless.
There are just too many things that affect the operation to offer clear solution.
Before calling service technician, open following link for Bosch troubleshooting resources, including contact information for Bosch.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Repair most tankless water heater problems yourself, same day, any brand, for $320
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help, and to share your tankless solution.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 02, 2011 | Bosch Water Heaters
FVD interface failure is flashing. How do I reset the water heater?
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Nov 06, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am having the same problem as posted by jek01 on Aug 1, my Rheem Tankless Hot Water Heater is not powering off, after two years of use with no issues. I also have to turn the breaker off and wait a short...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike
jzklipper@aol.com
Oct 11, 2009 | Rheem Tankless Hot Water Heater...
Water starts out hot,after a couple of minutes it goes cold.
check the connections between the controller. try disconnecting it to see if that makes a difference. 76 means that it's either the PVC board of the connection between the controller and the tankless
Sep 27, 2009 | Water Heaters
Rheem powervent2 water heater not starting
I am guessing that their is a flag control(switch) in the airstream of the vent and it is now stuck in the closed position due to the snow, maybe. Find the flag switch and make sure it can move freely. It must move freely for the venter fan airstream to operate or move it.
Jan 24, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
265 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
