Question about Goodman Heating & Cooling
I've changed out my central heat and air ,with a larger unit , after 5 weeks working fine ,now if my air conditioner ,hot water tank and stove is on along with a few minor appliances my main breaker trips , my main breaker is 150 amps the max for my box , i've heard that you can wire directly to a power meter through a breaker
  • 3,361 Answers
No,you can not wire directly to a meter. All wiring must come through the circuit panel or sub panel.
150 amps is sufficient to run what you describe. You may have a weak main breaker or loose wiring to these appliances. Place a amp meter on a incoming supply wire at the main, while you monitor amp draw have someone go around the house and turn on all these appliances. If it trips at less than 140 amps you have a bad main.
I suspect you will find a bad neutral wire on one of these appliances.
Posted on Sep 30, 2009
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
I have a new motorhome and the air conditioner only reduces the inside air temperature by 2 degrees on a hot day. e.g. outside air temp 26 degrees inside temp 29 degrees. After 2 hours of a/c running with...
Can you tell me what size/make of motorhome you have? Certainly doesn"t sound right to me, and I've been working on them for over 15yrs. Whether it's a 13,500 BTU or 15,000 BTU, it should be plenty as long as motorhome has any insulation at all. I assume you have central air from ceiling?
The manufacturer usually states that the AC unit will supply 20F below ambient.
Is compressor staying engaged all this time?
May 22, 2011 | Dometic Rooftop RV Air Conditioner
On a back boiler central heating system my hot water works fine but cant get my central heating working i have changed the pump there are no motorised valves on the system i have checked the the expansion...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
May 09, 2011 | Water Heaters
I have a Vaillant Time Switch 110 and for the last week or so the overflow pipe has been pouring water out. I have had the boiler turned off hence no hot water or central heating for the last week but it...
Your pressure relief valve is probably bad, replace it. You might want to tap on the expansion tank to see if that is empty. If it is full, replace it.
Mar 07, 2011 | Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Central haeting ok but no hot water
If the valve runs at other times, the valve is OK. you have a relay somewhere that is not sending signal to the valve when in that mode.
Trace down all the relays for that cycle and check voltage going int, coming out, and to see if the coil is enrgised.
Jan 01, 2009 | Heating & Cooling
Powermax boiler 155, when boiler reaches operating temperature the presure relief vale blow's off at 3 bar, when it cools down the presure go's down too, right down to zero needing a water top up before a...
Sounds likes you have a hot water system. Some where you have an expanion tank that is full of water and it should be half full. It will a round tank above the boiler and may even have a site glass on the end off it. It will have a special valve on it to lower the water level in the tank. The tank is to absorb the expanding water as it gets hot, and releases it when it cools down therefore preventing your relief valve from popping off.
Oct 14, 2008 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
