Question about Nikon Coolpix S210 Digital Camera
I am getting a lens error every time I turn on my camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Posted on Dec 31, 2009
Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
According to ehow:
Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Cameras
    Tip
    Sanyo digital camera showing lens error 1114 or 112
    Hi.
    If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
    This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
    If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
    If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
    If the camera had been exposed to sand or dust, try blowing canned air on the lens.
    If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
    Also call the number listed on the owners manual to get support from the manufacturer.
    Check also the links below for more troubleshooting in case of lens error:
    Lens not retracting on digital camera.
    Lens Error.
    on Apr 09, 2010 | Cameras
    My cannon camera lens will not open when i turn it on.
    you will have to take the camera to a service station to get the lens repaired. the motor that drivers the lens is damaged giving the above error. thanks
    Apr 20, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
    Lens error, restart camera.How can I restart the camera IXUS 60?
    Since the camera is locked after lens error, you will restart camera removing batteries.
    If this does not help, then you are in one of the following conditions:
    Lens error and lens does not retract.
    Try helping lens gently back in while you turn off the camera holding the button at same time.
    Lens error and lens do not extend.
    Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
    If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
    The lens must be disassembled by a technician to fix the problem.
    If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
    Here you can get a quote on repair: Repair
    Aug 22, 2009 | Canon Cameras
    Lens error when turned on unit, with buzzing sound
    Aug 15, 2009 | Nikon Coolpix S210 Digital Camera
    When i turn my camera on i get a lens error 113,0,0,0 what is that and how do i fix it?
    The lens/zoom has tendency to stick. Try newest batteries and try several times to turn on and off. If all else fails, Kodak will fix it for $50
    Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
    Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
    Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
    More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
    Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
    "Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
    Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
    Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
    http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
    Apr 17, 2009 | Canon PowerShot A630 Digital Camera
    A460 lens error, restart camera
    The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
    Jan 02, 2008 | Canon PowerShot A460 Digital Camera
    Lens error
    wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
    Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
    Nikon Coolpix S210 Digital Camera Logo
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
