Question about Cycling
Rubber brake pad rubs on rim.
Brake is rubbing on rim and making an annoying noise. How do I adjust ?
  • 921 Answers
Take a small or medium size cresent wrench put it on the brake pad holder slot (the metal piece that adjust them up and down)and slightly tweak them in at an angle.. the brake pads will now be at a slight V angle to the rim this should quiet it down..if there's no room to do this then you"ll have to loosen up the brake cable a little to expand it out..remember its spring loaded so have you hand hold it together and slowly relax you hand then tighten with the other, or theres one more way which is probably a lot easier...adjust the cable screw barrel down a few threads if you can then you"ll have the room needed to angle them in.
Posted on Oct 03, 2009
Bad sqeeking while driving nd turning 1997 chevy blazer
Sounds like it could be the brake pad indicator. When the brake pads start to go bad there is a small mettle lip that makes a sound to warn you before they get too bad and fail.have them checked.
Aug 28, 2014 | 1997 Chevrolet Blazer
Front wheel noise
The first thing I would do is inspect the brakes. The brake pads have a metal indicator that will start to rub when the pads get low. It will make a really annoying high pitch squeal. It could also be a condition known as metallic squeal. This would be a metallic particle in the brake pad that is causing the noise. Replacing the pads is a guaranteed fix for this. It could also be a backing plate rubbing or any number of things. Checking the brakes would be a good first step. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 02, 2012 | 2006 Saturn Vue
Back hand brake rubs on pads cannot adjust basic hand brakes
If you can't adjust your brake position by using the adjustment screws you can loosen the wheel bolts and physically change the tires position to make it fit within the brakes. If that doesn't work take you bicycle into your local bike shop and have them check your rim alignment.
May 06, 2011 | Cycling
My brakes are scrubbing and antilock light comes on, also when ever i back up, my front left wheel makes a very loud noise. kind of like rubbing metal. whats wrong?
the noise is probably the ware sensors on the brake pads making noise the noise lets you know that the brakes are getting thin are are ready to be replaced.if you let this go to long you can damage the brake rotors, make sure you check to make sure the caliper is not sticking on the left side being this side is making more noise ,a stuck caliper can cause premature brake pads ware .
Mar 05, 2011 | 1997 Chevrolet Lumina
Next mountain bike replaced brake pads but to tight. wheel won't spin
Take the wheel off and look carefully to make sure the rim is not touching the pads, then straighten the wheel making sure it isn't rubbing the frame anywhere. You probably need to adjust the cables to restore the cable length lost while compensating for pad wear.
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Feb 21, 2011 | Cycling
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
Bearing problem? in 2006 Pilot
Even though you had the brake pads replaced, and since the sound you describe is a "rubbing" sound, I would suspect that the brake caliper piston is sticking and causing brake drag. The only way to check is to pull the wheel and check the caliper. If it is sticking, it will wear the pad out quickly and wll generate heat. After driving, check for excessive heat coming from the wheel. It could be a wheel bearing, but I would check out the brake caliper first. Sure hope this helped. Good luck.
Jul 20, 2009 | 2006 Honda Pilot
Squeak
how about brake calipers?
squeaky noise is common from brake pads going against the brake disc.
This is caused by lose calipers or stiff calipers unable to fully open up. This makes the brake pads very close to the brake disc.
When you are travelling at a certain speed, tension on the wheels may cause it to incline inwards or outwards at a very small degree but that is enough to get the brake pad to rub against the disc causing the squeak.
Another possiblity is the brake disc rubbing against the disc guard. Usually metal and behind the disc. You said you had a collision, this may have distorted the disc guard causing some parts to touch the brake disc.
May 28, 2009 | 2003 Nissan Maxima
My BRAKE light came on and I thought it was my parking brake
Rubbing noise usually indicates that your brake pads has worn down, and it's rubbing against brake rotor. It's more like grinding noise rather than rubbing, right? And for the brake light problem, as brake pads wear down, brake fluid level goes down too. Your car is equiped with a brake fluid level sensor. So, check your brake pad first before adding brake fluid.
Apr 25, 2009 | 2000 Nissan Maxima
Cycling Logo
132 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
