Question about Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump
Whisperflo Pump 1.5 Hp problem
When I came home from work I noticed the pump was not running, when I shut the power off and back on all it does is hum and the pump does nothing. Any Ideas, time for a new pump? Its about 5years old.
  • 557 Answers
The pump is probably fine the motor is the problem. If it just hums it might just be the capacitor on top of the motor. Don't know how long it sat there not able to start. Was the motor extremely hot ? If it got too hot may have damaged the motor. Motor is replaceable without replacing the pump head.
Posted on Sep 30, 2009
Whisperflo Pump vibrates very loudly while running
Make sure pump motor is sitting on the resiliant pad. Also bearings may be ready to go
Nov 29, 2012 | Pentair 1.0 Hp Whisperflo Pump
I have a 1 hp whisperflo pump for my pool it is exactly two years old I came home to find out that the pump was not on. The pump was warm to the touch I checked all the breakers to no avail the pump never...
You would need to use a meter to make certain you are getting 230 volts all the way to the terminals on the back of the motor. If you are, you most likely have a defective motor, or at the least a blown or open motor start capacitor on the motor. All of these motors also have a thermal switch that shut off the motor when it gets to hot, then it will cool down, you will hear a click, and it will run again for a short period of time. This is caused by a broken cooling fan inside the motor, or dirt or leaves blocking the vent holes on the bottom of the motor.
Sep 02, 2011 | Pentair 011486 WhisperFlo High Performance...
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost...
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
May 22, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
3/4 Whisperflo will not prime
once you figure out why it's having trouble priming, you can reduce the discharge side with a valve to adjust the flow to what you need. You can always always reduce the discharge side but never the suction side.
Jul 01, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
My Whisperflo Pool Pump is making a racket. Is
Stick a large screw driver on the motor in the area of the bearings and on the pump housing ... stick the handle to your ear (notice I said to your ear ... not IN your ear) Listen. Often you can determine the source of the noise in this manner.
My money is on the impeller. You will need to replace the seals when you disassemble the pump motor from the pump housing. I found a dime in the impeller recently ...it made a racket until the impeller wore down in that area.
May 02, 2010 | Pentair 1.0 Hp Whisperflo Pump
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump Logo
661 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
