Question about Philips 32PT6441/37 32" TV
32dw television the tv keeps switching on to lashing red ,there is no pattern to it, sometimes you can switch it back on straight away and other times at least a hour other times it does,nt happen for days the picture is sound on the digital but not so good on anologg we have just moved house ,has that any thing to do with it
    An expert whose answer gotĀ voted for 100 times.
  • 108 Answers
There might be some weird out in wiring between Reciever and Picture tube. the issue is big. contact authorised service personnel
Posted on Dec 22, 2007
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
Old tape player, System Video 2000 had once tape stuck inside, the tape was taken out but now when it tries to load it, it turns the head over the reel where its supposed to go but stops short of final...
Hi ridic.
It sounds like you have a defective Mode-Switch. This is a rotary switch that tells the microcontroller chip what position the loading mechanism is in. It's a very common fault in many brands of vcr and is usually fixable without replacing the switch. The switch can be taken apart and the contacts inside can be cleaned, don't panic, it splits in half and can be easily clipped back together.
You need to locate the switch, it will either be on the bottom of the mechanism itself or located on the motherboard underneath the mechanism. The mode-switch is circular, about the same size as 2-pence coin (UK Currency) and has 1 moving dial. Look carefully at the switch as it should have a timing mark on it, this will be needed to place the switch back in the right position when cleaning is complete.
Look at the centre of the switch. There should be 4 little clips holding the dial on the switch. Carefully prize the dial away from the rest of the switch using you fingernail to gently un-clip the clips. After some teasing the dial should separate. On the dial you have removed there will be eye-lash type contacts, treat these as if they were made of eggshells, Very delecate. Put the dial to one side for a moment. On the remainder of the switch you should see circular tracks which will be tarnished. Using a cotton bud of cue-tip ( those sticks you clean your ears out with) and some alcahol based cleaning solution, remove any contaminents from the tracks until they shine. Once done return to the dial you removed ealier.
Carefully wipe the tips of the metal lashes with the same solution but Do Not go 'against the grain' clean from the bottom of the lash, going up. Finally before you clip the dial back onto the switch, use your finger to elevate the lashes slightly to give a better contact with the switch once clipped back together, but maintain the angle of the lashes, do not bend them straight up. After clipping the switch back together, allign dial with timing position you noted earlier. Put the vcr back together and give it a try. Post back results and good luck.
Jan 26, 2011 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
What About Bob
Feb 19, 2008 | Televison & Video
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
