Question about Minolta XG-A 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
How do I open my minolta XG-A Camera to change film ?
    Scholar:
  • 185 Answers
First push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Posted on Oct 03, 2009
  • 571 Answers
Pull out the rewind-crank (on the left hand side spool) and lift it. This will open the back of the camera. Be sure to rewind the film first or you'll get it all exposed.
I just bought the minolta XG-A, will I be able to adjust manually the shutter speed? I just bought it only, still has not been shipped. I bought it mainly for a film photography class but I just read that...
Minolta XG-A can work in full manual mode. The lowest shutter speed is 1 second and it had Bulb mode where the shutter is open as long as you press the button.
Sep 12, 2013 | Minolta XG-A 35mm SLR Camera
I have many lens for XG-A what other minolta bodies will they fit
The XG-A, like the other X-series cameras, uses the older Minolta SR lens mount. You're pretty much limited to the SR- and X-series cameras. They will NOT fit the newer Maxxum bodies, for example, which use the newer Minolta AF lens mount.
Dec 19, 2012 | Minolta XG-A 35mm SLR Camera
I have a Minolta XG-A camera, and i can take a picture but the shutter is stuck?
My shutter does that when there is low light, or just slow shutter speed. You could try changing those settings, otherwise, last time mine got stuck, I loosened a screw on the bottom right under the shutter release button and the shutter just snapped back into its place.
Jun 09, 2012 | Minolta XG-A 35mm SLR Camera
Thhe camra will not advance the film or take a
I used minoltas for a number of years while going through college, though unfortunately this problem is fairly common- was a few years back but first time it happened to me i took the camera in for repair and if i recall theres a part that just breaks inside (number of years, cant remember the part).
It would have cost me round £60 to repair- bout 6 times the cost of the camera from ebay- I eventually just started buyin a new one from ebay every time the problem cropped up again.
I realise it may not be what you want to hear if your particularly fond of your camera, but the cost of replacing a part may very well be more than the camera is worth.
At the moment I have a minolta XG-M sittin on my shelf, hoping to track down some service manuals and see about taking it apart- I'll let you know if i find anything out, even with my fancy digital camera i still miss using the old 35mm.
Nov 04, 2009 | Minolta XG-A 35mm SLR Camera
Strange Foggy line across view finder of Minolta XG-A
sounds like liquid damage. take the bottom cover off and see if there is any rust or corrosion. if all is ok and the camera is working, don't worry about it. it has no effect on print quality.
now if you find rust or corrosion your camera is about to become a fancy paper weight. not repairable economically.
Jul 18, 2009 | Minolta XG-A 35mm SLR Camera
Mirror lockup for minolta XG-1
Sounds like the shutter lubrication has dried out causing the closing curtain to stick. DO NOT try spraying an oil into the camera to try and fix this, it will cause more problems and could destroy the circuit board. I would recommend sending the camera to a shop specializing in the overhaul of older cameras. You might try www.united-camera.com They have been repairing cameras since the fifties and still repair the XG series cameras
Dec 11, 2008 | Minolta Maxxum 50 QD 35mm SLR Camera
MINOLTA XG-1 & XG-9
If everything lights in the camera when you test it ,it means the battery is alright,try this trick"Rotate the film advance connection at the bottom of your camera using a nickle (not the battery compartment) the one directly at the bottom of the shutter and should click if there's not you have some bigger problem.Good luck.
Sep 30, 2008 | Photography
I have a minolta XG-1 camera and I've ordered instruction booklet but for now can you tell me how to open the camera to put the film in?
Hi - You can download the manual by clicking the link underlined in blue below:
minolta XG-1
See page 15:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 19, 2008 | Cameras
Minolta XG-se Camera Owners Manual
If you can find the manual for the XG it can be used. the se ( special edition ) is the same camera.
Aug 14, 2008 | Photography
Minolta XG-A 35mm SLR Camera Logo
461 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
