Question about ViewSonic VX910 19" LCD Monitor
Monitor disconnected monitor from my laptop( windows xp ) after reconnecting cannot display any info . cannot swithch from laptop monitor to viewsonic. i have used windows restore prog. have reinstalled viewsonic drivers. have tried FN+F2, F3. can u help?
  • 152 Answers
Have you tried if the monitor on another computer?
otherwise it must be bad configuration.. try right clicking on the desktop, click on properties, configuration, and then you will see 2 monitors.. if you go in advanced you can also play there to tell wich one will be the firts monitor..
you could also reinstall the video drivers of your laptop and there will appear an icon on the task bar so you can configure how will the screen be working..
Posted on Dec 19, 2007
  • Asdrubal Perez Dec 19, 2007
    just to make clear something.. you must reinstall the drivers of the video card.. not the monitor..
The Bright/Contrast window, controlled from the monitor itself, keeps popping up. The select pane continues to switch between the Bright selection and the Contrast selection. When it finally stops...
Sounds like your monitor is going bad. You might get some more use out of it if you power it off for a couple hours and try again but my guess is this is a heat-related failure that is common on ViewSonic monitors.
Jun 30, 2017 | ViewSonic Vx2250wmled LCD Monitor
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
I bough the LCD model VA2231w- LED every time I turn it on then it pop up that change the resoluyion to 1920/ 1080P I don't know how to do it. So please help. Thanks Thai Nguyen
This would be the Native resolution. That your display functions and displays best in.
Windows XP, Vista and Windows 7.
(1) RIGHT mouse click over your desktop.
Windows XP will differ - but same basic idea to navigate and make this fix.
Pictures show from a Windows Vista Machine (extremely similar to Windows 7)
(2) Click Display settings
(3) Now you'll see a slider bar, Native Computer Display 1680x1050 resolution.
Some computers can not support this resolution and may cause non operational situations.
If the display setting is not on the slider bar. Chances would be that it's not a supported Resolution.
"Older computer" If the display doesn't show while trying different resolutions - do not click apply and wait. the screen will return to it's previous setting. ViewSonic VX2235 has a Setting that could be used to Disable this annoying message - Revert to ViewSonic lightdark_2.jpg
Nov 15, 2010 | ViewSonic VX2235WM Monitor
I have this monitor - ViewSonic VA712 and when i use it, turn the PC on, the monitor power status light turns green, then display turns absolutely black (still the power status is on GREEN). Can hear from...
Very common problem with Viewsonic and all other brands of failed moniotrs is due to bad caps as you can see here:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find for further help.
Sep 04, 2010 | ViewSonic VA712 17" LCD Monitor
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Vertical Vs Horizontial display, no VGA rotate icon to change it
On some systems I have seen "Ctrl, Alt + arrow" change the orientation. That works on the XP's at work, but not here at home. But it's worth a try.
Jan 29, 2009 | ViewSonic VA902 19" LCD Monitor
Viewsonic e70
high resolution may selected press f 8 f 8 contineusly when pc initially on then highlight on safe mode you will see the display
Dec 27, 2007 | ViewSonic E70 17" CRT Monitor
Viewsonic monitor ,no video
Black borders on side of screen. Video driver issue or no video driver installed; Resolution was changed and monitor could not adjust. Monitor needs to be manually adjusted.
Getting into Windows Safe Mode For information on how to setup your video card resolution, see document CH000190 ... This is the most basic Safe Mode option and has no additional support.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
