Question about Vacuums
My central vacuum system will not shut off. I had
My central vacuum system will not shut off. I had to pull out the electrical cords to shut down the system.
  • 694 Answers
Please provide more infromation, especially brand. They do differ.
The problem could be as simple as a bad switch to shorted wires somewhere that you need to locate.
Posted on Sep 30, 2009
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
Myu easy flow central vacuum wi not shut off
This could be because of 2 things....
first, the on/off switch may have been accidentally hit and is forcing the machine to stay on at all times.
Second, the relay in the unit may be defective and stuck in the on position. Less than 5 years should be under warranty. The easy way to tell if it is this problem tho is to unplug one of the low voltage wires from the side of the unit. These are usually located near the power cord going into the machine. If the machine stays running it is the Relay. However if the machine shuts off, the wiring in the vac system may be crossed out somewhere causing the machine to stay on.
Nov 04, 2010 | Easy Flo EF2300 Central System Vacuum
My nutone vacuum system won't shut off when I pull the hose out of the wall...any thoughts
The relay that turns the machine off from any of the several places where you connect, is probably stuck.
The relay is operated by low voltage. When you connect your hose, you comlete the low voltage circuit and energize the 110 volt system, and the machine comes on. When you pull the hose out, the relay is suppose to release.
those are my thoughts
I hope this is of value to you.
a
Sep 27, 2009 | Broan-NuTone CV450 Central Bagged Central...
My Sharp Vacuum, Model EC-S2365 just stopped working in the middle of vacuuming. I'm not sure what happened and I can't turn it back on. Any suggestions?
Just before it shut down were you pulling on the cord? For it to shut down like that it almost sounds like the electric cord has a break in it-probably at the plug
Jul 14, 2009 | Sharp EC-S2365 Upright Vacuum
Motor won't shut off on central vacuum
Your relay is bad. This is very easy to change out yourself. There are several websites that sell this part online. Some websites offer free tech support.
Mar 01, 2009 | Broan-NuTone CV350 Performance Bagged...
My cv450 nutune wont shut off, I have to pull the power switch
It should be the relay and that is very easy to change out yourself.
Jan 10, 2009 | Broan-NuTone CV450 Central Bagged Central...
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Hayden Premier Motor Pulses
there are several possibilities here, its possible the low voltage relay is bad, possible that the carbons on your motor are worn, or may even be a thermal sensor in your unit shutting it down, ive even seen improper assembly of motor which cause wires to be pinched and have shorts in them from the manufacture, course always check your power cord to the wall and test your outlet with some other appliance.as you can see several possiblities, most of which unless your knowledgeable in electricity i wound not atttempt on my own. highley reccomend taking to a vacuum cleaner shop to have checked out at least, they may even be able to sell you the part to fix it yourself
Mar 24, 2008 | Hayden Industries SuperVac 6000 Central...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
