Question about Canon PowerShot A540 Digital Camera
When turned on, camera shows low battery or immediately powers down. Batteries are Duracell rechargeable NiMH. Meter shows weakest battery to be 1.25 V. Canon PowerShot A540 about 2 yrs. old, bought new
  • 30 Answers
SOURCE: Canon PowerShot A540 Digital...Problem
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Posted on Mar 25, 2008
SOURCE: CANON POWERSHOT A530 LOW BATTERY READING
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
SOURCE: Powershot S5 IS wont turn on
was it ever left in the sun?
Posted on Mar 14, 2009
SOURCE: CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!! Glad I'm not the only one... I don't know what to do! I have gotten brand new rechargeable batteries and instead of getting 250 shots, I only get like 20!
Posted on Jul 25, 2009
t00nz
  • 4738 Answers
SOURCE: My Powershot A620 will not power up from batteries
If it's working using the external power input, then it's likely a problem with either the batteries, or the battery terminals (they may need cleaned or "bent up" a little to make better connection).
Here are some simple things to try for a camera that won't power on. They won't work for every case, but they're worth a try.
Posted on Sep 19, 2009
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Camera turns off within seconds batteries are new
Are You Using Regular Or Alkiline?
cameras eat batteries fast. the best cameras have rechargable battery packs.
i'd use energizer or duracell. try to stay away from alkiline rechargables as they wear out fast. try Nickle Medal Hydrate Batteries (NiMH).
Aug 13, 2009 | Nikon Coolpix 5700 Digital Camera
Flashes low battery with only a few shots. Battery is new. Also what brand of rechargable batteries do you suggest?
Aug 10, 2009 | Canon PowerShot A560 Digital Camera
Camera will not turn on
It may help to remove the batteries for a few minutes or clean the contacts. Repair of cameras is more expensive than replacement, but it may help to clean and charge the batteries as described below.A friend asked me to clean and charge her new 2000mAh Duracell batteries as described in the next link. Those batteries are still going strong after four months of normal use and have not been recharged.Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. http://www.google.com/base/a/4210404/D13...Also, digital cameras reset to original settings if batteries are removed for one minute. Time varies with function/camera. Check display/setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged/cleaned batteries and restart camera. The ultimate non-physical repair for software-using devices is reset by removing power ... VCR/DVD players one month.Most NiMH rechargeable batteries lose charge and should be recharged when not used after two weeks, but Duracell and RayOVac new formula 2000mAh NiMH batteries hold charge one year when not used. Also, 2000mAh batteries seem to have a longer life. Did not like these batteries at first, but have 12 over five years old and all are still as good as new. Higher mAh batteries (about one year old) still work well in flashlights, but won't start my camera.CAUTION Do not overcharge! Batteries can be damaged. Use an automatic two or more hour Energizer Compact smart charger with temperature monitor, trickle charge technology, and safety timer ($9.76) at Walmart. Use pre-charged 2000mAh Duracell ($12.97) or RayOVac ($5.97) batteries (both hold charge one year) and a full cycle charge. To preserve battery charge, use the viewfinder.If batteries are removed more than a few hours, the date/time setting and other set-up information will be lost. If the camera is being stored for a long time, the batteries should be removed and stored properly.Carry and dispose of batteries in baggies, blister packs, or other containers to protect ends from short circuit. Batteries explode when short circuited. NiMH batteries are environmentally friendly and may be discarded with trash.The next link is about prolonging the life of lithium-based batteries which last from two to three years, but are very expensive. A Sony series G rechargeable 960mAh lithium-ion battery is $49.88 at Walmart.http://www.batteryuniversity.com/parttwo... ...Camera reports batteries low, but is it low charge or bad electrical contacts? Overcharging can ruin good batteries! The secret to making digital cameras work better is having good electrical contacts between batteries and camera.Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but camera will indicate "low" if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out. NiMH batteries should be recharged when camera reports batteries low. Old batteries can discharge over night, but may provide normal service immediately after being charged. Battery pairs no longer usable in cameras may work well in flashlights. Do not drop batteries or allow voltage below one volt.CAUTION To prevent memory card corruption, keep batteries charged, format in camera, and don't delete or fill card completely. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select, then click Stop and OK.Never touch battery ends or camera electrical contacts. Oil from fingers will contaminate contacts. Use batteries in matched pairs of same brand and rating. Do not mix old and new batteries. New will only do as well as old.Click source link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
Apr 10, 2009 | Kodak EasyShare C743 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Batteries
Are you using alkaline batteries? If so, consider rechargeable NiMH AA batteries instead. Digital cameras are notorious alkaline battery eaters. By comparison, modern NiMH rechargeable batteries will last much longer per use/charge than ANY alkaline battery (up to 5 times longer). If you don't have them, get them, you won't regret it. Look for a power rating on the package of at least 2,500 mah.
Jan 01, 2008 | Canon PowerShot A560 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Canon PowerShot A540 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
