Question about Philips 60P8342 60" Rear Projection Television
No remote Philips 60P8342
I have no remote and need to adjust the color. Is this possible or do I have to get the remote control sensor on the TV repaired.?
    Genius:
  • 1,694 Answers
I checked with my parts distributor = remote sensor no longer available.....Philips part # 932215244687...........................T.
Posted on Dec 24, 2007
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
I need to adjust the red and blue convergence lines on my Phillips model number 60P8342 television. I have had a repairman adjust it with the remote before but don't know how he did it. Can you give me...
Go to your menu.
you will need to find where it says like brightness.picture and such under that option you will have a convergance option. you will need to go there. from there you will be able to converge the 2 colors using the remote.
please do not forget to rate and comment about your experience with fixya today.
Aug 21, 2008 | Televison & Video
Convergence problem, wavey at bottom some color distortion
Common problem on rear projection TVs. Either replace the convergence correction board or repair it. Usually a job for a technician or at least someone familiar with electronics. The fix is to replace the STKs and probably a couple of resistors. Can provide more info if needed.
May 11, 2009 | Philips 60P8342 60" Rear Projection...
I have a 60 inch Phillips 60P8342 and the picure is blurry.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 14, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
Remote Control Sensor is broken
Remote control sensor no longer availible .........Philips part
You may have control at the set, but have someone stand back
away from set to judge your adjustments as too little or not enough.....................................................T.
Dec 19, 2007 | Philips 60P8342 60" Rear Projection...
Philips 60p8342
Probable bad sensr inside tv.....Philips part is no longer available
part # 932215244687..................................................T.
Aug 30, 2007 | Philips 60P8342 60" Rear Projection...
Repairing color television philips
Some tv's let you select menu from the buttons on the tv,on of the buttons will say menu and the volume and channel buttos will have a double function like an arrow to the right and left and arrow up and down,they also have a buttos that says select,press menu and use the others buttos to move thru the menus until you get to the color bar,if it is at minimum adjust it so you get your color back but if it is already in the middle the tv needs to be service.Philips sells universal remote controls that are already program to work your tv being a philips and you dont have to programe it and you can also access the menu.
Oct 02, 2006 | Abt Television ABT IJETABT01 WIRELESS RF...
Philips 60P8342 60" Rear Projection Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
