Question about Oster Golden A5 1-Speed Universal Motor Clipper 78005-010
Someone gave me an Oster A5 single clipper to sheer out goats, we are new to this. what size blade do we need and is there one or two blades on this clipper
  • 448 Answers
Can't help you with the blade you will need to shear goats, but I can tell you that there are many blades for the A5, as well as many combs that fit over the blade to let you adjust for the length of coat you want to leave. Amazon lists many blades and combs under Oster A5 Clipper Blades. They probably have brief descriptions of what each blade is best used for, as well as customer comments regarding their effectiveness. There are a number of other places that sell blades if you look for them with Google. Also eBay, but there you probably won't get a description of what blade is good for what.
Good luck.
Posted on Oct 02, 2009
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster a5 clipper not cutting,blades are new,a5 is new,2 days old
make sure the blades are connecting to your clippers turn the clipper on and attatch the blade they should click into place and should not pull off untill the release latch is depressed.
Aug 08, 2010 | Oster 76076-010 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
How do I put size 4 blade on clipper
The A5 clipper should have a locking hinge the hinge should be open and slide the clipper blade onto the hinge, now push on the clipper blade bachward and it will snap on. if you don't hear a snap sound the hinge on the clipper maybe worn out and don't have no spring tension.
Mar 27, 2010 | Oster Golden A5 1-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
Aug 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
178 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
