Question about IBM ThinkPad T30 2366 Notebook
When I open my computer there message saying check date and time setting and after that the lock sign appear
  • Charles Akintunde
    Charles Akintunde May 11, 2010
    what type of operating system are u using? Check if ur OS has already been activated.
  • IBM Master
  • 7,993 Answers
The Cmos battery is drained and needs to be changed.
Hope it helps.
Posted on Sep 30, 2009
When i open the laptop which is lg with model number lgc50,a message appear,and it says press f11 to begin lg recovery,and suddenly another message appear that says.....disk read error
Please check if you have any disk in your CD/DVD drive, if not then the issue is likely with the hard disk drive (which has all your data). We have to check if the hard drive has gone bad completely. Please take your computer / hard drive to a local technician and ask them to backup your data if possible. Then you have to replace your hard drive.
Aug 01, 2011 | Computers & Internet
How to change time and date
Follow this procedure to set the current date and time.
1. Open all three one-touch speed dialing panels.
2. Press [Data Registration]
3. Press [up arrow] or [down arrow] until <TIMER SETTINGS> appears, then press [Set]
4. Press [up arrow] or [down arrow] until <1.DATE/TIME SETTING> appears, then press [Set]
5. Register the current date and time using the numeric keys. Use 24-hour notation to enter the time (eg. 1:00pm as 13:00)
You can also press [>] or [<] to move the cursor without changing a number entry. To restore the previous entry, press (c) (clear)
6. Press [Set]
the message<DATA ENTRY OK> appears on the screen for a few seconds.
7. Press [STOP] to return to the Standby Mode.
May 13, 2011 | Canon MX700 Office All-In-One InkJet...
I try to sign into my Yahoo mail account and it says internet explorer cannot display the web page. All other sites work with no problem
Check you computer date. I experienced it when you computer is not set to the correct date, yahoo mail does not open.
Jan 21, 2011 | Computers & Internet
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Cant sign in to MSN Messenger it says Temporary Problem when i check the service site it says its running think i deleted a file
Hi there, my name is Alex and I am here to help solve your problem
A common problem to signing in to MSN Messenger is the date and time set incorrectly. You can locate this at the bottom right hand corner of the desktop. After setting the time and date correctly, you should be able to sign in without problem.
If Messenger gives problems and the date and time are both set correctly, exit MSN Messenger and exit the icon which is located in the system bar (next to the time and date) and then open MSN Messenger again.
I hope this problem helps..... If you have any questions or more problems, please feel free to ask me.
Nov 27, 2008 | Microsoft MSN Messenger Connect for...
Invalid certificate
your problem can solved by set your time and date of your pc so your date and time is up to date, you can set them by double click time icon under the top corner your desktop, set your date and time up to date, Fix Ya
Sep 26, 2008 | Google Gmail
Google Talk problem
To resolve this problem adjust the Date and Time Properties of your computer.
Sep 15, 2008 | Google Talk
Yahoo messenger
call your ISP and tell them you have a problem ti's probably your ISP's problem it's mroe than likely routing you in the wrong direction to connect to their server. I've had it happen to me numerous times with Time Warner internet.
Feb 02, 2008 | Yahoo YHT-630 System
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
IBM ThinkPad T30 2366 Notebook Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
