Question about Garden
How can i remove generator from motor honda - Garden
  • dhcarter2 Oct 01, 2009
    it a porter cable and the armtaer stayed on shaft ,the back cover also no way to get to bolts do you have manuel it;s a mod H451cs
  • dhcarter2 Oct 07, 2009
    You were wrigth two hits and it came off ,sorry it took so long to get back iwas sick thanks again
    President:
  • 986 Answers
The mounting bolts are located inside the motor take out the 4 bolts from inside and the gen will seperate,I hope this help you
Posted on Oct 01, 2009
  • Donnie Wilson
    Donnie Wilson Oct 01, 2009
    I just done one of these and that what I had to do ,had to remove the cover on the motor and removed the bolts,
  • Donnie Wilson
    I have one in the shop we just tore down I wish I could send you a phitchure
How do I remove the starter motor from my Honda G400 electrical generator?
If people could just learn to GOOGLE their questions...
Honda G400 Type VIN G400 1000001 1096409 Small Engine Parts
This is on the same website, it's for serial number G400-1200001-1519048, Honda calls it G400K1
(sorry, Fixya doesn't give me the option to set this as a link)
Either search on that website for Honda G400K1 or drop the following into your address bar.
http://www.ereplacementparts.com/honda-g400k1-type-qb6vin-g40012000011519048-small-engine-parts-c-37657_37658_37986_37705.html
Jul 18, 2016 | Honda Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
U How do you fix a Honda generator 1000i engine runs but no power at 120 out let.
if the motor engine is working and no power output then you need to check is there any power out from the generator motor directly (not in the power out put box I hope you already checked in there) generator motor coils could have busted due to over loads. so even the engine is rotating the generator it can't produce any volts.
Jul 31, 2015 | Honda Electrical Supplies
Have a B&S VOX 6500 industrial generator with Honda motor. Generation quit and no breakers flipped. voltmeter shows 3.4 volts on both legs when running. What happened? and how do I fix?
It may be just as simple as flashing the fields. Remove the end cap of the generator. Look for the brush holder on the top center of the housing The brushes may be worn out or the fields may have lost the residual magnetism. The brush holder has two wires going to it, a red (positive) and a ?white (negative). Hook a couple of wires to a 12 volts battery. Plug a lamp into the generator that will light up when it begins to charge. BE VERY CAREFUL!!!!! Start the generator and momentarily connect the two wires to the brush holder connections. Make sure you observe the polarity Two or three seconds is plenty. If this doesn't work remove the brush holder and check brushes.
Dec 17, 2014 | Honda Electrical Supplies
Clean carburettor Honda generator e-300
Remove it and soak it in "Sea Foam" carbureator cleaner. Should just be 2 screws holding it on. Get the service manual from Honda. Honda com Official Site of American Honda Motor Co Inc
Oct 02, 2014 | Honda Electrical Supplies
Honda eu 2000 generator surging
remove the throttle control motor spin motor a few times. I believe due to the minimal rotation required during activation a flat spot or build up results in a poor connection. Kicks down under load now. Back to the smoothnes of a new unit
Dec 28, 2012 | Honda 6370C - Parallel Power Kit For ...
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
1985 honda shadow vt500c pulse generator
hi,
locate the crankase cover to the left of the engine towards the lower end of the motor. if the bike has a center stand place it upon it t\and undo the crank cover once removed you will visually see the pulse generator it is like a large type style magnet. good luck
live free ride hard..
Mar 15, 2009 | 1985 Honda VT 500 C Shadow
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Nov 27, 2008 | Kitchen Appliances - Others
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
