Question about Goodman Heating & Cooling
Glow plug will not glow, on my Goodman 100 3 furnace
Ignition glow plug will not ignite (or lite), replaced it with a new one....I can light the furnce with a lighter and works fine but will not re-lite after the cycle.
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    model and serial number of the furnace, also the part number of the ignitor you installed? Was it an OEM part or a universal?
  • frankrhoney May 11, 2010
    is the glow plug in the direct path of the gas flow?
hotuna
  • 288 Answers
SOURCE: goodman furnace
Check the roll out switch(s) and the lock out switches. They are a small disc looking about the size of a nickle, with with 2 wires attached on them. There will be a re-set button in the middle that resembles a small peg. Push this in to re-set. As the glow coil shorted out, the fuse on the control board may have blown. On the newer furnaces find the main board and look for a car type fuse. If blown, replace. You also have the symptoms of a bad limit switch, by the clicking noise (the heat fan relay) and the blower fan running instantlly.
Posted on Jan 07, 2008
  • 46 Answers
SOURCE: no hot surface igniter
This is why swapping parts is never a good idea. It could be a board, pressure switch, or several other issues. I'm a service technician and realize that many furnace issues are difficult to diagnose over the phone, or internet.
Calling a qualified, NATE certified technician to diagnose and repair this properly is probably the best solution that I could suggest. Yes, there will be a bill and it will be expensive, but it will be a lot less so than changing out parts you might not need.
www.natex.org
Posted on Jan 03, 2009
  • 2461 Answers
SOURCE: goodman furnace won't ignite. No glow from ignitor.
yes if the ignitor has a very small crack on it it will not work replace it and see if it works but do not touch the end that glows when you put it in as the grease from your finger s will stop it working
Posted on Jan 08, 2009
  • 56 Answers
SOURCE: Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Posted on Feb 13, 2009
  • 587 Answers
SOURCE: electrical ignition goodman furnace issue with gas
A lot of times that's the flame sensor, it's usually dirty and can be cleaned with a piece of extra fine steel wool.
Posted on Nov 22, 2009
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
I have goodman Gupio75-3 igniter lights pilot but main valve wont open
Ignite r is bad if amp draw is to low on ignition glow will still glow but its telling the brain its not glowing so valve will not open change glow or thermo coupler it should solve your problem
Feb 20, 2015 | Goodman Heating & Cooling
Goodman GMP100-3 home furnace status lite is constant red
check continuity of hot surface igniter....open loop means replace igniter
Nov 04, 2012 | Goodman Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Goodman heater not igniting, coil does not glow. Do I replace the coil and would that not allow the gas to open if there is no glowing coil?
your correct the gas valve will not open ifnthe glow coil does not ignite the flame which then hits a flame sensor (looks like bent piece of wire usally on the opposite side of burners from glow coil) you can with a long lighter thats is used for lighting a gas grill light the furnace manually that will allow it to run through one cycle only. you must first have the door off to the burner area, have someone else turn the furnace up to when it turns the exhaust blower on. when that blower starts running you have to listen for a click , that click is when you will hold the lit lighter right where the glow coil is, the pilot will light and your furnace will run, providing its only the glow coil that is bad. you may show your ex how to do this and leave her do it for the rest of the winter that would help keep her off your back and you could kill two birds with one stone so they say. if you do get a new glow coil i recommend getting the new style they cost a little more but they are not as fragile, you cant touch with hands or bump the old ones but the new ones take a lot to break and seem to last longer. Good Luck
Dec 29, 2011 | Goodman Heating & Cooling
Electrical ignition goodman furnace issue with gas going out after glow pin lights up
Nov 16, 2009 | Goodman GMS90703BXA Heater
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Goodman GMP075-3 ignition problem
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
552 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
