Question about Philips 60P8342 60" Rear Projection Television
Remote Control Sensor is broken
The remote control sensor is broken and I need to adjust the picture controls. Is that possible without the remote, or do I have to have the sensor replaced and use a universal remote control?
    Genius:
  • 1,694 Answers
Remote control sensor no longer availible .........Philips part
# 932215244687........................
You may have control at the set, but have someone stand back
away from set to judge your adjustments as too little or not enough.....................................................T.
Posted on Dec 24, 2007
I have Kenwood 106vr receiver, still working but lost remote control. Is there other way to adjust the BASS & TREBLE directly in the unit?
Hello
Not possible to adjust the tone without the remote.
if you have the possibility for a universal remote like "Logitech" remotes its Recommended for such cases, that will be easier for you to control the the AVR system.
Jun 13, 2016 | Kenwood Audio Players & Recorders
Can't format picture without the factory remote on a emerson 50inch tv
For Emerson brand TVs, there is no such factory remote control to adjust its parameters. You have to get into its service mode option to adjust its settings. For this purpose, you have to make a service remote control; out of the supplied original remote control you have now. Converting the original remote control, to an adjust remote control (Service remote) is easy. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Converting the remote control to a service remote control, and to enter its service mode and adjustment details are given.
Oct 22, 2014 | Televison & Video
How do I tune my Technika remote to my technika tv? There are no instructions with the remote!
If it is its original remote control, without any adjustments, it should work with it. Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 11, 2014 | Televison & Video
Problem with remote control or TV sensor? (Sanyo lcd32xr8da)
From your detailed description, I assumes that the infrared sensor inside your TV has the fault. This part can be loacated just behind the infrared sensor window at the front panel of the TV. You have to open the TV, and desolder it out from position, note the type used, and repalce it. There are so many types of these. Pictures of some are attached here.
6_13_2012_10_34_39_am.jpg6_13_2012_10_35_19_am.jpg6_13_2012_10_35_37_am.jpg6_13_2012_10_35_53_am.jpg
Jun 12, 2012 | Sanyo Televison & Video
Can I brighten the picuture my goodmann tv without a remote control
As there is no Menu button on the frnt panel of your TV, you can't do any picture adjustments, without its remote control.
May 31, 2012 | Televison & Video
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
My Sharp LC-32SB24U will not power on from the remote. It will work if you push the button on top. I have another sharp lcd in the house and I tried that remote also but it still will not turn on from the...
Jun 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
The TV does not respond to the remote control. I have replaced the batteries in the remote control
May 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
How do i set up the Canon wireless RC-5 remote control? Is it a setting in the camera or a code for the remote??? HELP! I have lost my manual for the remote, I am shooting with an EOS Rebel. ...
There is no need any special setup. Be careful your remote control has a good battery. The above picture explains everything. First change your mode and than press remote control to take picture. While doing that you should point the remote control device to the remote control sensor of the camera.
Below picture shows that.
If you think that these explanations helpful please vote.
Jan 14, 2010 | Canon RC-5 Remote Control
No remote Philips 60P8342
I checked with my parts distributor = remote sensor no longer available.....Philips part # 932215244687...........................T.
Dec 19, 2007 | Philips 60P8342 60" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
261 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
