Question about Singer Sewing Machines
My singer 2515C machine is not stitchinh. properly,
My singer 2515C machine is not stitching properly, what could be the problem. I notice aproblem with the bobbin shuttle.
  • 22 Answers
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix.  take the spool of thread off, remove the bobbin.  look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
Posted on Jan 17, 2009
  • 323 Answers
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
Singer 6215 Stitch length dial not working properly...have to force knob to turn past 2.5...stitch lengths don't seem to change, either. Thanks!
How long has it been since you've cleaned and oiled your machine?
Your machine requires frequent oiling on the moving metal parts. Most likely the stitch length selector has begun to seize.
SINGER 6214 Manual Page 80
This may help:
Wheel on right side that controls the needle up and down is very tight...
The heated hairdryer may be a good choice to try.
Jan 05, 2016 | Sewing Machines
E99670 - keeps jamming after a few stitches. How can I fix this?
by the sound of it your tension is a bit light.e manual
you want the stitches to loop properly as described in th
i would recommend having it serviced by a singer repairman
Sep 12, 2013 | Singer 8280 Mechanical Sewing Machine
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
May 27, 2013 | Sewing Machines
Singer ce100 is skipping stitches when needle is in center position
You don't say what you are sewing so I'm going to give you general answers in hopes it helps.
1. Needles: There is no such thing as a universal needle. Make sure you are using the proper needle for your fabric. This goes for thread too... make sure it's sized for the needle.
2. Make sure the bobbin is threaded correctly (poorly wound bobbins will cause problems too)
3 Improperly threaded machine. Make sure you area threading it correctly with the foot in the UP position.
4. If you are a material puller... shop it. It is never good to pull your fabric through the machine as you sew.
5. Stitch length. simple rule: Fat fabric.. long stitch, fine/thin fabric short stitch.
I'm not familiar with your futura abut I've noticed new home machines take a way presser foot pressure adjustments... which can cause issues too.
Mar 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Singer 301A stitch jam
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Oct 28, 2008 | Singer 8280 Mechanical Sewing Machine
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
440 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
