Question about Procom (177653) Utility Heater
I'm trying to get my heater going this season. The pilot lights fine and heater will kick in but will only run 30 seconds max before it quits and I have to restart it. I've done this at least 20 times in a row. Any suggestions? Unit is only 2 years old
  • 456 Answers
Does this have a fan attached to it or does the heat just stay around the unit. Does this have a thermostat or is it manually turn it on and off?
Is this in the garage or house?
1) Make sure no fans are operating when you do this.
An external fan can either **** the pilot off or blow it out.
2) Make sure if it has a thermostat that the sensing bulb located on the back is not picking up external
heat source.
3) If it has an external sensing bulb, put it in a bucket
of cold wtaer. Then try to light the pilot
Posted on Jan 15, 2010
Glo warm gas wall heater
Sounds like a bad thermocouple. When they go bad, they won't open the gas valve when switched from pilot to on.
Dec 04, 2013 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Once I press the button to start the heater must wait a good 30 seconds or more before it stays lit when button is released.
That's normal. It's the correct way to allow the the Thermocouple and/or Thermopile to fully heat up.
If you have been turning the pilot light OFF after each use and then relighting it when you want to use the heater, that's really not necessary. Leaving the pilot lit during the heating season is a better way to go. If you think you're saying gas by turning the pilot light OFF and then relighting it again, when you want heat, you're really not saving a significant amount of gas or money. The pilot burning continuously, uses very little gas.
Hope this helped you. Please let me know. Thanks
May 16, 2011 | Heating & Cooling
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
Floor heater won't light
At the gas valve on the furnace, jump the two connections where the thermostat wires attach to, I think TH and TP may be marked on terminals. If it lights, you have bad wire(s) going to thermostat. If it still refuses to light, you may be looking at a new gas valve.
Dec 02, 2009 | Heating & Cooling
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Procom (177653) Utility Heater Logo
129 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
