Question about Janome Memory Craft 9000 Computerized Sewing Machine
Where do I get needles to fit my machine
Finding needles
  • 980 Answers
You can get the needles at any sewing machine shop and even in the large supermarkets or stores, they are standard flat side.
Posted on Sep 30, 2009
Finding a replacement needle
It really depends on the make and model of your sewing machine. Most machines take the 130/705 needle but there are some exceptions, so it's best to consult your owner's manual. You can also check with sewing machine dealer or repair shop. Or you cans search the internet for:
Make Model needle
Nov 25, 2016 | Sewing Machines
How to fit needle in nina 787 overlocker
Perhaps it is not the correct needle for the machine. There are some needles that are a tad bit longer than the standard sewing needle (my non-Bernina coverstitch takes a longer needle). Although not familiar with the 787, most Bernina sergers use the same needle as a Bernina sewing machine.
When installing the needle, be sure to push it all the way up (as far as it will go) when tightening the skrew.
If it continues to break the needle, the machine could be out of time and need service.
May 31, 2016 | Sewing Machines
Unable to buy needles
Hi, can I suggest that, if the machine was purchased near your home, that you contact the supplier for some information / support in finding needles. If you have tried this to no avail then try you enquire with a sewing machine supplier as to compatible parts...there must surel, be some that fits which is made by another manufacturer.
Jul 24, 2015 | Husqvarna Viking 1
My mom owns a Scandinavia 100 sewing machine Husqvarna viking. I understand finding parts for it is quite challenging, especially the right ones. I need Needles of system 130/705H. Help! Thanks...
http://www.amazon.com/s/?ie=UTF8&keywords=schmetz+130+705h&tag=googhydr-20&index=aps&hvadid=31589294077&hvpos=1t1&hvexid=&hvnetw=g&hvrand=17197811914288753541&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_5hzcn08ee3_b
Mar 09, 2015 | Husqvarna Sewing Machines
How to fit the bobbin holder called the shuttle into the machine correctly
Lean the machine at an angle so it will not fall out...Hook will only fit one way, then ring with "bull horns" that go to the top rear, then lugs hold it on then insert bobbin case
Mar 10, 2014 | Janome Sewing Machines
White sewing machine model 265 and cant find a needle.
I suggest using a schmetz universal needles,, using a needle from
a different machine isn't always a good idea unless it's a universal
one---and the correct one for the fabric being sewed
Dec 24, 2012 | Sewing Machines
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
Oct 08, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
I am having alot of trouble finding info for my white e-6354this is a vintage machine I realize but I can't get the top thread to pick up the bobbin thread
Rethread your machine, making sure your needle is not bent or dull, and please make sure that your presser foot is not sitting flat against the needle plate. Make sure you thread needle with flat side behind and the more rounded side facing you.
Lift the presser foot so that it will open the tension disks.
I hope this helps.
Jimmy
Apr 01, 2012 | White Sewing Sewing Machines
I have a white sewing machine model 415 and cant find needles to fit the machine
Hi. Sewing machine needles are standard sizes, so you shouldn't have a problem finding needles to fit. You use different size needles depending on what weight and type of fabric you plan to sew (I posted a chart that explains what size needle to use with what fabric).
What do you want to sew?
Robbie
Feb 26, 2010 | White Sewing 1866 Mechanical Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
