Question about Canon IXUS 80 IS Digital Camera
My camera Ixus 80 IS does not open any more and gives lens error, it does not go in or out (possible due to a fall in closed state). Besides that, I have no possibilities to retrieve my pictures from the Memoy card any more. External readers can't retrieve the pictures aswell. So for the 2 problems I'm looking for a solution. Downloading scan programs gave no solution, because the SDHC card does not communicate anymore with any system, What to do now?
SOURCE: Memory Card Error
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
Posted on Mar 31, 2008
Steve5
  • 423 Answers
SOURCE: ixus 40 maximum SDHC card
Your camera is not compatible with SDHC type cards. No 4gb cards for you. It looks like 2gb (non SDHC) cards are the biggest you can use.
Posted on Feb 25, 2009
wipdhuls
  • 133 Answers
SOURCE: len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
Posted on Apr 02, 2009
t00nz
  • 4738 Answers
SOURCE: Lens Error ixus 800 is
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Aug 02, 2009
  • 102366 Answers
SOURCE: Camera reads communication error when
Having gone over five months without a response, I assume my suggestion to use a card reader solved the problem.
Posted on Mar 28, 2011
How can i restart my canon ixus 80 (lens error , restart camera)
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 18, 2011 | Canon IXUS 80 IS Digital Camera
I have a Canon Digital IXUS 95 IS, it keeps giving me the "error lens, restart camera" error message. How do you suggest this can be resolved?
Mar 18, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Lens error. Restart camera
Lens unit is faulty is not zooming or working properly that why you getting lens error.
you can try to open camera and near lens unit you can blow with pump to remove any dust is not causing this problem if work then good other wise you need replace len unit
Jul 03, 2010 | Canon IXUS 80 IS Digital Camera
Camera was dropped and says "lens error, restart camera" but won't start
Restarting (turning the camera off and on) rarely helps. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 21, 2010 | Canon IXUS 80 IS Digital Camera
My cannon camera lens will not open when i turn it on.
you will have to take the camera to a service station to get the lens repaired. the motor that drivers the lens is damaged giving the above error. thanks
Apr 20, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lense error restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 11, 2010 | Canon IXUS 80 IS Digital Camera
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Len error restart camera canon IXUS 80 IS
Apr 02, 2009 | Canon IXUS 80 IS Digital Camera
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon IXUS 80 IS Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
