Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
TV went out and will not turn on
The tv was on and all of a suddon just turned black. The power light will stay on but turns red. The lamp light will also blink a while then it will go back to the red power button. Eventually all light on the front just go out and it shuts down. Is this the lamp? There was no warning. Is that typical?
  • Jeremyd Dec 19, 2007
    how?
  • mbstaff Dec 30, 2007
    This exact thing happened to my television today! Sunday, 12/30/07.
    What's the problem with it? Could it be the lamp?
    Melanie
    High Point, North Carolina
Willtab, when I pull the lamp will it tell me, I NEED REPLACEMENT????????????
Posted on Jan 15, 2008
    Genius:
  • 1,030 Answers
Have you pulled the lamp to see.
Posted on Dec 19, 2007
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
I have a Sony WEGA KDF-E60A20 TV. When I turn on the TV, it will stay on between 30 sec to a 1min. Then the screen will turn black and there is no sound. After about a minute, the TV is back on with...
Hello.
It looks like you have to replace lamp in your TV. Read owner's manual for info of how to do it. It is not very complicated. Lamp have to be replaced every 2.5 years of average use.
If you will still have same problem after lamp replacement you will have to replace lamp ballast as well, because your old lamp was long overdue and could inflict damage on it. It is not very probable and there is no way to know it for sure without replacing lamp first.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
try rehooking up your cable for your tv, if it dont work just call your tvs manufacturer
May 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
