Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Slipping while in gear--clutch? - Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
  • 437 Answers
Transmission belt may have stretched; it may be time to get a new belt on it.
Posted on Sep 30, 2009
What allows clutch to slip so much to not move car.
-Possibly time to replace new clutch.
Good luck
mai
Nov 10, 2014 | 1990 Toyota Camry
2007 Kia Sportage clutch slips in high gear
If engine revs increase but road speed does not increase, your clutch is coming to the end of its life and needs to be replaced
Jun 06, 2014 | 2007 Kia Sportage 2.0
Clutch slipping
if it started slipping in 4th then get a new car. The transmission is going out. 4th gear is connected to the clutch and you will need to replace the clutch and the transmission when it gets worse. It costs in upwards of 2,000 dollars to replace and or rebuild. Good Luck
Mar 24, 2014 | 2004 Mitsubishi Eclipse
Freelander clutch
check out the operation of the clutch system .IT is difficult to rationalise a hydraulic clutch because if it is slipping that means that the pressure plate is being held off and not fully engaging but it also means that when pressing on the clutch the there would be no problem changing gears . But if you have a cable clutch operation then it is possible that the cable is jamming inside the outer cover and holding the pressure plate off ( slipping) and gear problems. If it is cable then replace the cable first. If hydraulic then it may mean box out for a new clutch kit.
Jan 12, 2014 | Cars & Trucks
2003 FORD FOCUS CAN'T CHANGE GEAR BUT CLUTCH IS NOT SLIPPING
if clutch not slipping, problem is in the shift linkage or cable could be damaged or need adjusting.
Jan 31, 2012 | 2003 Ford Focus
WHen under load the motor revs up and it seems that the Clutch is slipping, it has 100000miles and I suspecting the clutch or the high / low range might be messed up, its a 4 plus 3 manuel transmission.
If it feels like the clutch is slipping, chances are it is. If there was a problem in any component that has internal gears, you would have grinding noises. Gears cannot slip. As the clutch wears more you may hear grinding when you try to change gears but that is because the clutch won't fully disengage so the gears are spinning too fast to shift properly. Before that happens, have the clutch replaced.
Aug 02, 2011 | Chevrolet Corvette Cars & Trucks
How do i know my clutch is gone out
You can do a third gear test.. Try and start it in third and ease out on the clutch. If the car stalls your clutch is ok. if it slips most of the way, you know its not in good shape.
Other signs of a shot clutch is while its in gear you can floor it and the rpms will shoot up and the mph will not rise as fast, this is the clutch slipping on your flywheel.
Mar 03, 2011 | 1992 Toyota Celica
Clutch slipping in second gear only
Wave washer on the face of the clutch basket may have lost its tension, clutch friction plates may be wearing thin as she's an old girl. Some automotive (car) oils not specifically designed for wet clutches when used in a bike will cause the clutch to slip as they are designed to leave a deposit on friction areas. This will require a thorough flush and a few oil changes in quick succession.
Check the return function of the clutch release arm on the crankcase, they can bunch up the rubber shroud and not return fully. Good luck and Cheers.
May 02, 2010 | 1982 Suzuki Gs 550 L
Slips when shifting gears
If the clutch slips, the clutch disc is worn out. The clutch hydraulic system only "disengages" the clutch.
Nov 09, 2009 | Toyota Cars & Trucks
Slipping in first gear - 1996 Kawasaki Vulcan VN1500
only two things going on here, first the clutch is out of adjustment, no enough free play, the next is the clutch plates and springs need replacing.
Sep 15, 2009 | 1996 kawasaki VN 800 Vulcan Classic
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
144 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
