Question about Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15)
Post code 99 in motherboard abit al8
Hi, I turn on the computer but the motherboard get the post code 99 and the computer not work. What is the problem?
  • 27 Answers
Check your motherboard's owner manual. Try removing the processor/ram/video card to see if that will give you any clues.
Posted on Sep 30, 2009
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
My computer powers up then immediately shuts off. My mother board Abit IN9x-Max32 sits at code 99. Help??!!
I'd like you to take a Close L@@K at the Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Post back in a Comment after your inspection.
Do NOT forget to use Anti-Static Procedures.
Regards,
joecoolvette
Mar 25, 2013 | Abit IN9 32X-MAX Motherboard
Abit as8 post codes 21
Hello here is the homepage:
http://abit.ws/page/mi/download/download_driver_detail.php@pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AS8&pSOCKET_TYPE=LGA775
Post code 21, is a memory/ chipset problem.
It could be a problem with a ram module, or a Pci sound card or a graphic card. or powersupply.
Try to remove any add in cards, and try to boot with only one stick of ram.
Good luck
Jan 12, 2013 | Abit AS8 Motherboard
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
I updated my bios and cleared the bios on a Abit AL8 motherboard and it now has a 00 code and wont start up can you help me
If you have damaged the bios then all you can do is try and re flash it.
A damaged bios usually means its new motherboard time
Sep 14, 2010 | Abit AL8 Motherboard
How can i reset bios on the fsb 1066 motherboard
Just look for the silver battery. Either remove battery and replace, or look for jumper (closest to battery with one pin showing, and two covered by the jumper) Remove the jumper and place over middle and previously uncovered pin, then move back to origional position.
Hope this helps
Wayne
Tech Rehab
http://techrehab.t35.com
Aug 11, 2010 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
I want to install 2nd sata hard drive to abit al8-v motherboard
Hi!
Yepp, you'r at the right track, BUT if you want that external disc to be an internal disc you need to take it out its case and put in you pc, Then its easy for your OS to find it. when you done all the inside connections, no need to select master or slave as it is an sata disc, rightclick on your computer, select "handle", the select "diskhandle" almost at the bottom in the new window that opens, now you will see the new disc, rightclick on it, formate it and give a new name(letter)....thats all.
Good luck
Nic
Apr 09, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15) Logo
1,784 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
