Question about Water Heaters
I have a Rheem Warrior Class Model 72-52-2 240/208 wattage, manufature date 9-2005 in a trailer house. The breaker keeps tripping. When I reset the breaker, it will heat for a minute and then trip again. Will a new heating element fix this? Thank you
  • 3,600 Answers
Yes it is most likely shorted out to test remove the wires after you have disconneted the breaker turn off the water and drain water then remove it and replace it.
Posted on Sep 30, 2009
Rheem gas power vent water heater model# 21vp75e-19 keeps tripping gif breaker when plugged in, help please
Check where wires go into housing, look for a bare or nicked neutral (white) wire. GFCI's only trip when the neutral makes contact with ground.
Mar 08, 2014 | Rheem Water Heaters
User manual for Rheem 21V30DV
1) 21V30DV is 2006 6-year mobile home (manufactured housing) natural-gas, atmospheric-vent water heater
2006 Manual does not show on internet.
Replaced by Warrior series
http://www.rheem.com/documents/warrior-dvx-warrior-dvx-use-and-care
http://hometips.me/Mar/Mobile-home-water-heater-illustration.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Add comment with specific question for possible help.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 02, 2013 | Rheem Water Heaters
Water heater tripping the breaker
Copy following link for troubleshoot walk-thru for electric water heater tripping breaker:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Aug 11, 2012 | Rheem Water Heaters
The water heater breaker keeps tripping and I have to reset it to get hot water. It continues to be a problem, what should I do?
Thermostat could be bad causing the breaker to trip due to it being shorted. It's either your breaker or the thermostat, more than likely the upper thermostat is bad.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Rheem warrior glass serial num r0296b08705 model
You need to first determine if the burners light or not.
As long as the unit wasn't run with a dry tank the unit should not have been affected by continuous water running, unless it got hot enough to damage the thermocoupler which is an easy replacement. That is the part that your pilot/ignitor warms so that the gas valve will open the gas line to the burners.
Aug 12, 2011 | Rheem Single Water Heater Thermostat
I have a Rheem warrior glass water heater model number 71-30 s in my mobile home. Recently had frozen water pipes and had to take the entire water pipe from the water heater to the main water box off to...
Before I spent the money on a new heater I would check reset to make sure it did not trip. I would also check element and make sure you are getting flow thru outlet and that it did not plug up with rust and mineral .
Depending on the water quality where you live I would expect to get at least ten years use out of a electric heater. Thank you.
Feb 10, 2011 | Rheem Water Heaters
Rheem warrior glass serial num-rh1098154699 model num-71-40d b That is all the information i collected off my hot water heater we have no hot water at all and i dont know how to fix this problem...
The label would also say if water heater is gas of electric.
That would be helpful information that could lead to troubleshooting.
Serial number tells us water heater was made on Nov 1998, which tells us the manual will not be on the Rheem website.
So if you have electric water heater, and no hot water.
There can be 4 causes.
1) Circuit breaker is not delivering 240 to water heater. Test top two screws on upper thermostat to see if tank has 240V.
2) ECO red reset button is tripped. Open top cover on tank and push reset button.
3) Upper thermostat is bad. Replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 24, 2010 | Water Heaters
I have no hot water in my house. I have a Rheem model #82V52-2 with a 50 Gal tank, mfg date 11/2005. Please help I don't want to have to pay someone to come over. Thanks!
There are several possible points of failure in your electric water heater. The easiest to check requires no more than a look at your main electric panel and locating any tripped circuit breaker. If done properly, it should even be marked as 'Water Heater.'
These breakers are not immune to failure; they can trip for no reason if defective. If you find a tripped breaker which may have two breakers visibly mechanically connected, reset it by pushing it to the tripped end first and then to the 'On' position. If there are no faults in your heater elements or the breaker, you may be finished already.
The other failures would require that you obtain a multimeter so you can check continuity of several items. Such meters, most digital today, can be found at auto parts stores, Radio Shack and other electronics outlets. If you have a Harbor Freight Tools store in your area, you can buy them there for well under $10 US and the simplest will do the job. You shouldn't have to spend more than $20 US to buy a usable one and any of them are very useful for simple home and auto troubleshooting. They are also numerous on eBay:
Digital meters
If you decide to go this route, comment back to this thread and I will guide you further.
Jul 18, 2010 | Rheem Water Heaters
Water Heaters Logo
851 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
