Question about GE Monogram ZDI15C Automatic Icemaker
I tested the ice maker by pouring water in it and it made ice could the selinoid be frozzen and how can I fix it
    Scholar:
  • 103 Answers
Sounds like if you put water in ice maker and it dropped ice but won't make ice on it's own then the water valve or water filter is bad. Replace filter, purge air, then check a day or two later to see if it is making ice, if not then replace water valve on back of unit where water line ties in at.
Posted on Oct 01, 2009
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
Ice maker
Kevin if your model number ASD2622HR is correct you can test your water control vave after removing the front cover.of the ice maker using a ohm test points you should get from the N and V test points should show around 150 to 350 ohms of resistance. Then ohm test test ports L and H test points are for testing the mold heater. The dual water control valve ca still be defective mechanically so tell me is there water or ice still remaining in the ice slots? Pour tap water into ice maker and allow to freeze and if ice maker cycles and drops the ice into ice bin then does not refill with water that will indicate a defective water control valve. You should get around 72 ohm's of resistance. A new dual water control valve=> 67005154 Dual Inlet Water Valve
Replacement Ice maker=> D7824706Q Ice Maker Assembly12_17_2011_2_58_46_am.jpg
If you have any questions please ask. Click Here to get most all the information you need at top and left side of page=> Whirlpool Matag Customer Assistance
If helpful please rate but please ask if you have any questions, Thank You Sea Breeze
Dec 16, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
My freezer is not making ice and the water only drips out of the water side
There could be a couple dif problems. If the temp in the freezer is not below 6 degrees the thermistat in the ice maker will not call for water. The selinoid in the water inlet valve for the freezer may be bad. The ice maker itself may be bad.
To test the inlet valve switch the hoses and see if it calls for water when you call for water in the door. To do this you will need a 1/4 inch nut driver. Remove the panel in the back of the fridge on the outside. Push the connector inwards and pull the hose out. Most inlet valves you can do this with. Switch the hoses and push the water through the door button . If you cant do this you have 2 choices. Either call a technician to test the inlet valve or take a gamble and replace and hope this works.
If the inlet valve is good and the freezer temp is below 6 degrees replace the ice maker.
Jun 30, 2011 | Whirlpool 21.7 cu. ft. Side-by-Side...
Water started pouring out of the icemaker and out the dispenser. When we opened the freezer door water poured out of the icemaker and down the whole freezer. Opened icemaker flap and water stopped. Turned...
Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
Feb 11, 2018 | KitchenAid Superba KSRG25FK Side by Side...
Model 106.57036601 Ice maker quit working couple days ago had water off in whole house, had to repair a water pipe in the restroom.
There are a couple or three ways to test your ice maker and dual water control valve to identify the location of the problem. By looking at what the ice maker did on its last cycle or the lack of a cycle will help a lot. If ice maker has old cubes then the ice maker has not cycled and that tells me that the ice maker has been turned off or it has become defective. Another test is to pour tap water into the empty slots if there was not old cubes there. Allow the water to freeze and if the ice maker cycles and dumps the cubes into the ice container that would indicate a defective dual water valve=> 4389177 Water Valve Kit- Double Outlet The first three numbers of your model tells me it was made by Whirlpool and that tells me that removal of the front cover of ice maker you have test points. If me knowing what I know of ice makers I would be prepared to change both ice maker core=> 2198597 Ice maker - Replacement
Below is a short You-Tube ice maker help tutorial by the Appliance Assistant that can be very helpful. Should you have questions please ask, Thanks, Sea Breeze
Jun 10, 2011 | Kenmore 56733 Side by Side Refrigerator
Have model gs5svaxva00, (whirlpool frig) ice maker stopped making ice over the weekend but water dispenser still works?
The problem is one of two places,
the ice maker is the reason or the dual water control valve=> 4389177
Try pouring tap water inside the ice maker if cubes are not there. Let freeze
and if ice drops into the ice bucket then the water control valve on the side
that feeds ice maker is bad.
GS5SVAXVA00 Parts
List
Look up in the scrollbar and go to page 17 and you will see the water
control valve listed an item 5 and item 15 is the ice maker thermostat. That or
the ice maker module are most times at fault if the water control valve for ice
maker side had 120vac connected to it water would possibly flow. I have found
that sometime if the ice maker is bad just to replace would be the best route,
Tell me how the water test goes and if someone has a multi meter or ohm meter I
will answer how to test those components, Thanks, Sea Breeze
Click
here=> 2198597
Ice Maker Assembly
Feb 10, 2011 | Whirlpool GD2SHGX Refrigerator
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
No water flow to the ice maker
Here's a kinda clumsy solution: I had a similar problem--for several years I'd manually pour in just enough water to fill the spaces. Sometimes the ice maker would then start to work again for a couple of weeks. We have hard water, so I assume it's a problem related to minerals building up somewhere.
Anyway, most recently, I had some cubes frozen in the bottom of the drawer so grabbed the drawer and pounded it in and out a couple of times, bumping it onto the back wall a couple of times. Voila, the maker started making cubes. Now every time I get cubes, I first pull out the drawer halfway and then shove it against the back wall. ...seems to work--the drawer is always filled to the brim no matter how much ice I take. It's been a couple of months now so seems to be working...
Mar 21, 2009 | KitchenAid Refrigerators
GE Monogram ZDI15C Automatic Icemaker Logo
125 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
