Question about GE Ovens
I HAVE A GE PROFILE JT950 DOUBLE WALL OVEN WITH CODE F7 . WHEN F7 IS DISPLAYED OVEN WILL NOT FUNCTION AND THERE IS A CONSTANT BEEP NOISE. THE POWER HAD BEEN DISCONNECTED FOR 24 HOURS AND THEN OVEN APPEARED TO BE OK BUT AFTER ABOUT 4 WEEKS PROBLEM RE-OCCURED . HELP ! DOES THIS SOUND LIKE THE CONTROLLER OR KEY PAD. PROBLEM OCCURED WHEN OVEN WAS NOT IN USE .
Powerman
  • 68 Answers
SOURCE: GE Profile Oven FTP18 - F7 Code
The F7 problem is usually caused by a short circuit between segments of the ribbon cable connecting the touchpanel to the ERC. Open the touch panel. Insert a slip of paper (yes paper) between the two segments of ribbon cable where it exits the slot in the touchpanel. Try to work the paper down as far as possible. A piece of file card may work better. See the attached photo. If you have a metal touch panel, also add slips of paper between the ribbon cable and the edges of the slot. I have shared my solution with over 795 folks with the F7 problem. Most report success. Cleaning the contacts is a myth. It is only a short time solution as when you move the cable you are temporarily disrupting the short circuit, but it will grow back. The short is caused by what is know a dendrite. It is a growth from the silver traces on the membrane switch conductors. If you want more technical information, contact me at hutchipop@yahoo.com. The solution should work for all ovens made by GE including Kenmore as far back as 1998. Don't be concerned about putting paper in the top of the oven. GE places a set of instructions in the top of the oven. Many folks have replaced touchpanels only to have the problem return.
Posted on May 29, 2007
  • 4 Answers
SOURCE: GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Posted on Aug 02, 2008
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile slide in range with the F7
No, this is not an appropriate way to solve this issue. You will need to replace the ERC, in this case. One, or more of the function buttons are stuck. This has caused a short in the control. Replacing the ERC, will correct the issue properly.
Posted on Oct 28, 2009
SOURCE: F7 error message on GE oven
one other comment about the F7 message having delt with this stupid oven for years and after replacing touchpads and controls the touch pad is the cause of the F7 in one of 2 ways either the ribbon cable is shorted (the repair for this has been posted by several people and is good) or a stuck button .One cause of the stuck button at least in my house has been steam coming from the oven flowing over the touch pad this can get moisture in the touchpad shorting it out causing a button to stick giving an error message also making the oven unusable....what I did solved the problem I figured I was going to have to spring for a new touch pad so I peeled it off the front of the oven got under the edge with a knife and lifted it off (it is stuck on fairlly well but will lift off) once this is done i squeezed every button between my fingers and flexed the touchpad back and forth (flexed not bent) ..I noticed the edges are not sealed well allowing moisture between the mylar surfaces poor design! i replaced pad and sprayed edges with silicone spray soaked the front also around the window area figuring the silicone would get between the surfaces and help prevent this problem Ta Da oven all better too bad I didn't figure this out sooner but I hope this helps someone....GB BodhaineG@aol.com
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
Posted on Oct 01, 2010
!0 year old GE Profile Double Oven. Control Panel repaired but oven is again not working with a "F7" mal function indicator on panel. Model # JT 950 S0A3SS
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Ovens
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 | GE Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
Best of luck!!
Thanks
Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem so far.
My oven is also a JT950 and the builder installed it in our home back in 2000. Our F7 issue started about 2 years ago. For a few months, "clearing" the panel and/or shutting the oven off at the breaker panel would temporarily solve the problem. About 1 1/2 year ago, however, the F7 would come on and continually beep. A repairman looked at the oven and replaced the control panel at a cost of $600 (ugh...). That solved the problem until a month ago when the F7 continuous beeping began again. There was no way I was going to pay another $600. for "temporary" repair and I was thinking of replacing the oven. Luckily, I came across the above-mentioned fix-it information and took a chance by following the simple instructions provided.
Jul 02, 2008 | GE Profile JT952 Electric Double Oven
Ovens Logo
87 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
