Question about Intertherm P3RA-048K Air Conditioner
Intertherm filters I cannot find where to buy filter for my furnace. I am in BC Canada
  • sjmayhew Dec 09, 2009
    I actually had a new frame made and can change the filters super easy and for very little expense :) Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Tese flters should be located on the front panel or the door, but here in oklahoma, we buys the cut to fit , mohair types at lowes dept. stores.
Posted on Dec 09, 2009
Prince George BC Canada
I know exactly what you are needing and I have not been able to find them for sale. Most parts houses wont waste time on such a cheap part. I'm in Texas, HELLO CANADA!!! I usually just use a 1/4" or 5/16" self tapping screw and make my own hole. Screw that front panel to the unit itself. If you have to remove panel often, then find some butterfly style screws of some sort. Hope this helps!
Sep 04, 2017 | Intertherm Heating & Cooling
Vanderhoof BC Canada
http://www.intertherm.net/DealerServiceLocator.aspx
Jan 08, 2014 | Intertherm 56000 Btu Gas Furnace
I have an Intertherm furnace that now will not turn on....Its a gas unit..electronic ignition,,, and from what I could read on the furnace..the model number is G2RR050C12...geez..I hope thats...
The filter is in the bottom of the furnace. Turn T-stat off and go to furnace. Unplug furnace. Top door comes off first, pull up on top door then out and down, set aside. Bottom door lifts up and then out. There is ur filter at the bottom. azeddysac@yahoo.com change ur filter then hit me back
Nov 06, 2010 | Intertherm Heating & Cooling
Where can i buy filters for a intertherm furnace in zebulon nc or raliegh nc?
I am not familiar with your area in particular but furnace filters are normally available at home and harware stores. Most air filters are 1inch thick, or close that dimension. You should measure the length and width and find one of the same size. Don't worry about high effeciency filters, all the furnace needs is a basic filter.
Oct 16, 2010 | Heating & Cooling
I have a intertherm furnace and need to know how to tell the proper filter size this is a mobile home
The best thing to do is buy a washable horsehair filter from home depot and cut it to fit. They are green in color and you cut any size you want. They slide in the door of a gas furnace or along each side of the A coil in an electric furnace. That is your best bet. Most of the time the furnaces comes witha washable filter and it is thrown away after afeew times. Rus
Dec 06, 2009 | Refrigerators
Where do the filters go on the Intertherm MGH055AB?
The filters on an Intertherm usually go on the inside of the front panel
Mar 06, 2009 | Intertherm P3RA-048K Air Conditioner
I think I have the wrong air filter in electric furnace
Measure the width and length, then buy a filter that size.1" is correct for thickness.
The arrow points into the return. Not into the room.
Feb 18, 2009 | Intertherm P3RA-048K Air Conditioner
A Good Fit and a good quality air filter
The kit I have seen is a foam filter that coveres the inside of the furnace or air handler door and has soem wires to hold it in place when off. This can be made easily if you have a welding supply close by buy some 1/8 inch steel wires and bend to fit your door. bend the ends at 90' the the rest of the wire and put the ends behind the door and the filter between the 2. Hope this helps and please rate me accordingly. Good Luck
Jan 25, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
307 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
