Question about Dacor EHD3618SS Kitchen Hood
How do you get the light bulb out of the hood?
How do you get the halogeon light bulb out of the hood? There is a stainless steel rim that it sits in, does this come out first and how do you get it out if it does?
There is a tool (suction cup) that dacor provides with unit or you can order the "kit" online for $30. i used some gloves with latex coating on palms to get "decent grip" to spin it out. that stainless stell rim actually pops out on my ventilation hood....it is similar to recessed lighting baffles...spring loaded....it may give you a bit more room to manuever your fingers.
Posted on Sep 06, 2010
Definately use these gloves. I got the job done without them, and got little slices on my fingers! Those bulbs have sharp edges on their face!
Posted on Sep 13, 2013
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
Hood Light Problem
This is a light socket problem, and it has plagued hoods for years simply because grease builds up there and is acidic. One fix is to disconnect the power and wash the socket with alcohol, then buff with steel wool being careful to leave no steel wool behind. After cleaning you will need to re-tension the little aluminum/brass button at the bottom of the socket by placing a screwdriver under it and gently lifting it about 30 degrees upwards. Replace the bulbs with ONLY the stated wattage bulbs indicated on the panel.
Mar 05, 2010 | GE Profile Designer JV936DSS Stainless...
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Vent Hood
when a bulb blows, it takes excess current. if breaker is not sized to a hood, then damage to module can occur at time bulb goes
Apr 20, 2007 | KitchenAid KHTU165RSS Stainless Steel...
Dacor EHD3618SS Kitchen Hood Logo
542 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
