Question about Samsung Digimax S730 Digital Camera
Camera turns on, then freezes at "screensaver" picture I have set
Then it won't turn off without removing the batteries, and it won't take any pictures or move from the screensaver screen. Leaving for vaca in 2 days! HELP!
SOURCE: Auto Focus Not Working
Mine did the exact same thing and i hav only had it for 3 months; there is nothing i could do exept for taking it to the professionals
Posted on Mar 16, 2007
SOURCE: Camera won't turn on
not sure if you have the same problem..but i have the same camera and when i turned it on the screen was all white..it still worked and took pictures but i could only see them on the computer.. i had my friends dad open it up and he found a foam like piece that fell from somewhere and was causing a wire to short out in the LCD screen.
Posted on Mar 23, 2007
wicabuss
  • 48 Answers
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Posted on May 01, 2009
mail2pvs
  • 390 Answers
SOURCE: white screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Posted on Jul 05, 2009
solasknows
  • 199 Answers
SOURCE: Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Posted on Jul 13, 2009
Canon eos 600d, takes a picture on turning on and freezes. When I turn off and on again, it takes a picture again and freezes. Cannot access menu or any other button. how do I resolve this issue?
Camera electronics has developed a mind of its won and has gone crazy. You need to have it fixed or replaced whichever is cheaper.
Make sure the battery is good since many newer electronics operate erratically when the battery condition is not up to par.
Jun 13, 2016 | Canon EOS 600D Rebel T3i Digital Camera
The camera turns on but only loads the 'cyber-shot' screen then freezes, lens doesn't open, can't view past pictures or do anything including turning it off. Camera was not dropped or man-handled in...
I'm sorry to hear that the Camera is not working as expected. I suggest you to follow the steps mentioned below to check if the issue can be resolved.
Perform the below steps to power reset the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
To Initialize option in the Camera can be done only if you're able to access the Menu of the Camera. To Initialize the Camera select the INITIALIZE option from the Main Settings Menu option from the Settings Menu of the Camera to OK. (You may try this only if the Menu is accessable).
If the issue persists, service may be required.
Thanks for using FixYa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony DSCW320 Digital Camera
When turning the camera on it freezes, it stays on the opening polaride picture. When this happens it won't turn off unless you remove the battary. The picture is blurry and the lens will not go back in...
Please help us solve this problem. My Polaroid camera also is in the same situation. The picture isn't blurry though, but yeah, camera can't be turned off unless the battery is taken out. Is this a battery problem? -J.
Aug 20, 2010 | Polaroid t1235 Digital Camera
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
The LCD screen freezes and turns all white then cuts off when taking pictures.
was the camera drop?
are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
Here are the steps you need to do
-Try to use your camera without Memory card
-Turn on camera and press the zoom button make sure that the lens will move properly., If camera hungs it means the camera lens is the problem
-If youturn on the camera then it will just display white screen and shuts off when taking picture Charged the battery for 4hrs
-after charging the battery and still camera freeze it means your camera needs of service please call kodak toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EasyShare V1073 Digital Camera
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
When I take pictures they are white washed.
Here are the steps:
1.Remove the battery/batteries and the memory card from
your camera
2.Reinstall the battery/batteries into your camera
3.Without the memory card,turn on your camera.
4.Set the camera to Auto Mode and the flash is set to Auto.
5.Try to take a picture.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Regards,
Neerak21
Sep 23, 2009 | Kodak EasyShare C713 Digital Camera
Camera freezes up and no funtions will work, not even on/off
i am having the same problem. it said file error so i turned off my camera and now it wont turn on at all. It charges and turns on but it wont turn on to take pictures?
May 29, 2009 | Vivitar ViviCam-X30 Digital Camera
Camera freezing
TRY RESETTING THE CAMERA
Jan 05, 2009 | Fuji FinePix S7000 Digital Camera
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Samsung Digimax S730 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
