Question about Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player
Movie has no red color only green and yellow
Sony dvd player projects movies only in green and yellow, no red is projected.
  • Sony Master
  • 3,289 Answers
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Posted on Sep 30, 2009
How should I hook up a dvd player? Which one of the input jacks. I am using rca connectors
mikehomco,
On the rear of the DVD locate the composite video output and audio outputs. The connectors will be RCA females. Video is yellow, right audio is red and left audio is right. Connect one end of your patch cable to the appropriate output color. On the TV find the video input one. Connect the yellow, red and white ends of the cord to the same colors on the TV, video input 1. If your TV has a source selection button use it to locate video input one. If not use the menu. Go to input select and choose video input one. Enjoy the movie.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Our Panasonic DVD-RV32 player plays movies in blk & white even if the movie is a color movie....
this is a cableing issiue. I assume you are playing it through a SVHS cord. check to see which pins may be bent. If it is true and none of the pins are bent then you simply need a new cable.
wikipedia talks about these color and non color pins http://en.wikipedia.org/wiki/S-Video
If you are not using SVHS cables and instead are using the RGB or red green and blue RCA connectors then you may have them on the wrong color on either the DVD or the TV get a light to be certain the color you were trying to line up was the right one.
You may have a bad cable here as well. on the back of the unit it doesn't say RGB it says component Pb Pr and Y but just look at the colors of the RCA jacks. Side note here you can use a different cord to test them out, even one of the red, white and yellow cables, Just make sure that the jack goes green to green and so on you don't have to have a green cable in between it, it is helpful but not necessary.
also for reference here is the manual http://www.panasonic.com/consumer_electronics/live_manuals/media/pa029/pkg/manual/PA029_02.html
Mar 25, 2011 | Panasonic DVD-RV32 DVD Player
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Audio Players & Recorders
How do i get my sons dvd player in color. it plays every movie in black and white
Make sure the connection to the TV is correct. Yellow(video) jack from the DVD player will go to yellow jack of the TV, white to white(audioL) and red to red(audioR) for compsite audio/video connection. Red to red, green to green and blue to blue for component connection.
Dec 29, 2009 | Sony DVP-SR200P DVD Player
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Phillips 60 in projection - colors yellowed
you have 2 problems one of youy tubes is low on fluid and the convergence is way off.
Sep 11, 2009 | Philips 60P8342 60" Rear Projection...
Hook up not right
You may have connected the video cable to the (red) component jack. The three component jacks are always next to each other and are color coded red green and blue. The composite video jack is color coded yellow and only one cable is used for video. If you are using the component video, three separate cables are required.
Mar 22, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player Logo
1,188 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
