Question about Samsung Pleomax SCM-9000 Mouse
Mouse pointer keeps wavering in the screen. Im not
Im using Pleomax mouse. It was working well. yesterday, I unplugged mouse and keyboard and dusted them. after that when i plugged them back and turned on the system the mouse pointer keeps wavering in the screen. Im not able to use the mouse. help please.
    Sergeant:
    Champion:
  • 203 Answers
Try to look for the proper signal, try to click the button on the mouse, or try to unplug it and plug it again.hope it work.
Posted on Sep 30, 2009
My mouse isn't moving on the screen
Hi I had this recently do you have a small oblong button right below the spacer bar you might have pressed it by mistake, while dusting etc, this freezes the pointer, also on my previous laptop I had the same problem but no button, so that was fixed by closing it down, unplugging it, removing the battery and replacing then switching back on, very important though to unplug from the mains......
Aug 27, 2012 | Razer Rz01-00280100-r3u1 Naga Mmog Laser...
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
I have a systemax syx-ms-7309 ser#106603641 i need to know the specs im having issues keyboard or mouse wont work and monitor yurns on says no signal and no picture but the toer has powe to it but th
first the monitor
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
if by now you gan get a screen
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the Ps2 or usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
this will apply to your mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Jul 16, 2012 | Systemax Ascent PC Desktop
Hi, I've been using my cordless mouse and keypad (logitech mk300) for 6 months. Yesterday, it suddenly broke down. Nothing strange happened, I was playing PES on the pc then, my pc froze. When I restarted...
also
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select users you will see who is using your computer
you might have to many programs loading at start up or you might have a virus run your antivirus program then
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
as for the mouse
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
dont forget to vote
hope this helps
Feb 06, 2011 | Logitech Wireless Access Duo Optical...
Click function keeps working
Usually happens with dust buildup between left click and switch causing sticking - multiple clicks. You could try cleaning it but would recommend getting a new mouse
Feb 01, 2010 | Logitech Cordless Mouse
Mouse keeps scrolling through pages
This sometimes happens to optical mice when they are used on a reflective surface. Do this:
1. Make sure there are no dust inside the mouse sensor
2. Use a proper non-reflective mousepad
If the above does not work, then there may be a hardware fault with the mouse. You may need to have it fixed or replaced.
NOTE: Please rate our help to keep this free service online
Jan 11, 2010 | Microsoft Wheel Mouse Optical PS/2 USB...
Mouse wont work
If you are using Windows 2000 or newer version just restart the system and allow it to stabilise before initiating any task ok. Good luck
Apr 27, 2009 | Samsung Pleomax SCM-9000 Mouse
Microsoft wireless mouse 700 works, slows, then stops
Seems like new batteries did the trick. Should start simple.
But I am not totally convinced. I will keep an eye on it.
Feb 17, 2009 | Microsoft Wireless Optical Mouse
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Samsung Pleomax SCM-9000 Mouse Logo
359 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
