Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Condenser clicks on and starts to run but clicks off after 3 or 4 seconds. And this keeps happening every couple of minutes?
  • Whirlpool Master
  • 1,606 Answers
You need to replace the overload/relay , which is plugged onto the compressor , with 2 or 3 wires going to it . This part is easily replaceable . Also , make sure the coils are clean under the refrig , of dust , lint , pet hair , etc .
Posted on Oct 03, 2009
LG bottom freezer not cold at all. The condenser clicks and goes on for about 10 seconds then kicks out . this happens every 8 minutes or so . Everything else seems to be working (lights,controls and
Please have someone check the start relay, run capacitor and overload on and next to compressor. These are symptoms of defective compressor start components, Thanks Sea Breeze
Look around the refrigerator fresh food section door for a model number should you need me to look up parts.
Dec 18, 2012 | Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
My compressor runs for 3 seconds - then shuts down for 3 minutes - then runs for 3 seconds
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Thetford Norcold® Model DE0061
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 10, 2010 | Kenmore Refrigerators
The refrigerator started to make a buzz/humming sound several months ago, It lasted only a few second and was infrequent. Then it started to become more frequent, and then started to last longer. ...
heatman101
Sep 26, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
KitchenAid Refrigerator KTRC22KKSS00 has stopped FREEZING. The cooling part works but the freezer doesn't, it's just cooling. The relay is klicking at least 3 times within 5 minutes. I don't have a...
just replace the relay and overload/ptc on the compressor,whats happened is the unit is running on both the start windings and run and overheating due to continued high current demand from the start windings,normally it uses these winding just to start the motor from a dead stop,then they open up via the relay and the run windings keep it running at a much lower current
Mar 15, 2010 | KitchenAid Refrigerators
Condenser not running
The condenser you are referring to could be the compressor. If it is clicking, that means it can not start. Let it cool for a while, unplug the unit. You may need to replace the starting components at the side of the compressor. This could be faulty. But if after replacing it, the compressor would still not start, then you have a bad compressor.
Check also the front lower grill, remove it and check the condenser if it is dirty. This is another cause of hard starting compressor.
May 28, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator and freezer
Is the fan behind the back panel underneath
running (condenser fan) may be dead or clogged
with something if not thats the problem if it is
running take a vac attachment and clean
the dust or blow the dust from underneath
the refrigerator (after turning it off)dont bend
anything,After verifying the condenser fan runs
and cleaning the condenser try it out
If there is no improvement and,
If the system has not been opened before I
would say there is a leak in the system
(low charge) Requires the
attention of a service person
Nov 23, 2007 | GE GSS25JEMWW Side by Side
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
