Question about Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
During the monthly test: Hardware Diagnostics Tools- Scheduled Maintenance ... it shows that the surface scan test HD535-2W failed ...so do I need to fix this? and how???
  • 788 Answers
You can download disk manager utility and run a comprehensive test.
Sometimes a good formatting will cleanup the disk and will mark bad sectors and they will not be written to.
If you purchased this hard drive yourself, you can in most cases return it for a warranty exchange if under 5 years and you have proof of purchase.
Posted on Oct 01, 2009
    Sergeant:
    Champion:
  • 203 Answers
Actually it just test your hardware, but you can still use it, it actually says that bad sectors cannot be fix, something like that, try to scan it and fix error.
Posted on Sep 30, 2009
Testimonial: "Thanks! So, you think disc cleanup & disk defrag will do it?"
  • Charlie De Guzman
    Charlie De Guzman Sep 30, 2009
    i think so, once you scan it, bad sector will be marked so it wont be us, but try to take care of your hardisk, safely remove it once not needed,
I have a 07,010.43:45789 error code pop up. Any ideas?
7,010.43: The Printhead is stuck in the tilted position,
or is not able to tilt forward to the print position, due to problems.
Reboot the printer.
Repair or replace the Printhead Restraints.
Has ink spilled ink around the Printhead that prevents the Printhead from moving to its center position? You should be able to push the Printhead right to left. Clean the Printhead area.
Is the Printhead stuck to the Wiper Blade? Start the printer in diagnostics mode and run idiags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5
Does the X-Axis Motor drive the Printhead to its center position (so it can tilt forward)?
6
Check the Process Drive for obstructions or damaged.
Ensure the gears are correctly aligned and homed.
Verify the process shaft and drive module shaft are at their home positions.
7
Has ink spilled on the Head Tilt Gear on its drive train (near left side of the Printhead)?
8
Use Service Diagnostics to run the Head Maintenance Wiper Clutch test. If the test fails replace the Head Maintenance Clutch.
9
Align the Wiper Assembly. Use Service Diagnostics to run the Wiper Drive Test. If the test fails replace the Exit Module.
10
Use Service Diagnostics to run the Load Maintenance Clutch test.
If the test fails inspect the maintenance drive system, replace any defective parts.
11
Verify the Head Tilt Gear engages. You can manually set the Head Tilt Gear.
12
Use Service Diagnostics to run the Tilt Axis Drive test.
If the test fails replace the Process Drive.
13
Use Service Diagnostics to run the Process Motor test.
Aug 13, 2014 | Xerox Phaser 8560MFP Laser Printer
Smart hard disc problome
It means pretty well what it says. That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual. Those things predict a hard drive crash, however it could take months for the drive to fail (or it could be the next minute). since it's a hardware problem the drive is going to die on you and you will have to replace it. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive. b> You could run the chkdsk disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now ,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
Feb 20, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
PRI master smart command failed
smart error predicted b> It means pretty well what it says. That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
open the laptop
get the drive out
Feb 07, 2013 | Microsoft Windows XP Home Edition
Dell 4500 says pri hard disk smart bad
open the laptop
get the drive out
Hope this helps.
Nov 21, 2012 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
On a monthly hardware diagnostics check,a surface scan failed the test.Is there a free tool to fix this problem avbailable to download?
This error often means that a physical spot on the hard drive has failed. Additional spots are likely to fail soon. Back up your data (build a recovery disc set if you haven't done so) and then get a new hard drive to replace the old one as soon as possible. (You may want to get drive cloning software - which will copy even the hidden recovery partition to your new drive.)
Rarely, the error means that a file is corrupted on the disc. Programs like SpinRite, http://www.grc.com/intro.htm , or HDD Regenerator, http://www.dposoft.net/ , may solve the problem. I'd still plan to invest in a new hard drive.
If your computer is still under warranty (with an extended warranty since you list Vista as the OS), contact the manufacturer about the problem.
I wish that I had better news for you.
(Drives will fail. This scan is meant to let you save your data before the drive completely dies. Since you have Vista, the hard drive was assembled at least 3 years ago and could be more than 6 years old.)
Mar 31, 2012 | Microsoft Windows Vista Home Premium OEM
Check engine soon light is on
take your vehicle to your locale autozone, they do free diagnostics tests. They'll tell you what codes your vehicle is sending out(Plus alot of information about that code, what needs replacing)
Good luck
Jan 21, 2011 | 2001 Nissan Xterra
I ran the short test for the ST350063 OAS SCSI Disk Device in PC Doctor hardware diagnostics test and it passed. I decided to run the long test right afterward and the Surface Scan test failed. The...
You could run it again, you probably have some bad sectors. The drive might be fine for years or it could die, very hard to tell. Hard drive failure is the number one problems on PC's next to spy-ware and virus's
What I would recommend either way, is back up important files and folder.
Dec 23, 2010 | Computers & Internet
Screen/graphics problem, distortions & low res issues
It is not a driver failure but it is a hardware failure. I have my own fz340e and have the same problem as yours. Now, my fz340e works fine.
Apr 02, 2010 | Sony VAIO VGN-FZ340E/B 15.4" Notebook PC...
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Samsung SpinPoint P80 SP1604N 160 GB Hard Drive Logo
1,164 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
