Question about Casio Office Equipment & Supplies
When I try to reset calculator (pressing the little thing on the back) it will not reset (not emptying the functions)
  • Casio Master
  • 8,064 Answers
If there is a reset button or a hole, the calculator should reset. If it is a hole use a paper clip and press firmly, though not to the point of bending the clip.
It might be well advised to specify the calculator brand: it makes things easier for us, for we cannot guess what machine it is.
Hope it helps
Posted on Oct 01, 2009
I want it to return to the 0 level it's 0.000000000
Press the setup key (to do this press 2nd F and then MATH). Now press 1 for FSE and select NORM1 by pressing 3. Your calculator should go back to normal. Alternatively, reset the calculator by pressing the reset button on the back of the calculator.
Nov 07, 2012 | Sharp EL-506 Calculator
How do I reset caculator? It is stuck on 0p
There is a reset button on the back of the calculator. Use a pen to push the button in and reset the calculator.
Oct 03, 2012 | Sharp el-531x scientific calculator
HP 48GX Says "DUP Error:
Do you have anything on the stack? The DUP function duplicates the top element of the stack. If the stack is empty then you'll get this error because the calculator can't duplicate nothing.
Aug 22, 2011 | HP 48gx Calculator
My TI-84 calculator keeps saying "ERR:INVALID DIM" whenever I try to graph a function. I have used many different equations and tried to reset the scales and stuff in the "WINDOW" but it keeps saying the...
One of the statistical plots is turned ON and you must turn OFF all the STAT PLOTS.
To do so
  1. Press [2nd][Y=] to access the stat plot configuration.
  2. Select [4:PlotsOff]
  3. Command PlotsOff echoes on main calculator screen
  4. Press [ENTER] to execute it.
  5. Return to your [Y=] screen to define functions to graph.
  6. When finished entering functions press the [GRAPH] button.
Aug 31, 2010 | Texas Instruments TI-84 Plus Calculator
HP48GX does not turn on
no sry get a new one
May 23, 2010 | HP 48gx Calculator
How do you fix an MA error when attempting to graph a function? I have even tried to graph simple functions like (X) or (5) and it still says MA error.
A. This is due to a mathematical error such as
  1. dividing by 0,
  2. an illogical operation,
  3. calculations outside the range of a function,
  4. using the exponential function with the [^] key,
  5. logarithm of a negative number,
  6. calculating the factorial of numbers larger that 69,
  7. what have you.
  8. Check the expression of the function you are trying to graph.
B. Reset your calculator and start again: Press the button on the back of the calculator; use a starightened paper clip.Draw the line y=XPress Menu.
  1. Use keys to highlight [GRAPH] and press [EXE].
  2. Make sure the screen that opens says Graph Func Y= at the top.
  3. On the Y1= line enter X (use the [X,theta,T] key under the [ALPHA] key.
  4. Press [F6:Draw].
  5. You should see a staright line passing through the origin (0,0).
Feb 18, 2010 | Casio CFX-9850G Plus Calculator
Functions don't work
The presence of the Fat arrows to the left of the Y1, Y2,etc = functions means that the Transfrm application is running. It takes over the graphing from the native OS.
You must uninstall it.
  1. Press [APPS] and scroll up to go to the bottom of the list of Applications.
  2. Highlight [ : Transfm] and press [ENTER]
  3. In the new screen with the heading "Transfm App" press the number that corresponds to uninstalling the Apps [1:Uninstall]
  4. Try to graph two simple functions Y1=X and Y2=2X.
  5. If these functions are graphed correctly you are back in business, if not turn Stats Plots off.
To turn Stat plots Off
Press [2nd][Y=] (Stat Plot)
Press [4:PlotsOff]
Press [ENTER]
If all else fails, Reset the Ram
Press [2nd][+] (MEM)
Press [7:Reset]
Press [1:All Ram]
Press [2:Reset]
Press [ENTER]
Press [CLEAR] to erase the "Ram Cleared" Message.
Jan 27, 2010 | Texas Instruments TI-84 Plus Calculator
Setting the VAT calculation function
Press and hold SET button untill set appeares.
Presa TAX RATE batton, enter requred tax. Press set button.
Job done!
Dec 22, 2008 | Office Equipment & Supplies
Sharp Elsimate 1611P 12 digit Calculator
It sounds like there is a printer error. Take of the cover where the paper is. There should be a little ink roller. Try taking this out and look in and see if the rubber band with the numbers on it is broken. If so, the machine is not worth repairing, unless you can get it replace under warranty. If it is not broken, try turning the machine on and off with the ink roll out of the machine. This should reset the print head as long as nothing is in there jamming it up. Good luck John
Jun 12, 2007 | Sharp EL-1611P Calculator
413 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
