Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Frige elec. board asm main control making click noise every 2 sec
I have a GE refrigerator that is 3 years old. The electrical board on the back keeps making a clicking noise every 2 seconds. I turned off the power twice, once for a few seconds. Second time for 10 minutes and when I turn it back on the clicking continues. The lights flicker slightly inside when the click sound occurs and the fan is not running. But I am quite sure the fan is ok. It's an electrical issue.
    Scholar:
  • 103 Answers
Main board is defective. Replace part # should be wr55x10552.
Posted on Oct 01, 2009
3 Suggested Answers
tech master
  • 120 Answers
SOURCE: refrigerator interior heating upwards of 90 degrees/freezer seems fine
is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Posted on Oct 15, 2008
  • 3600 Answers
SOURCE: GE refrigerator, the temp display was flickering,
If you are careful and can acess the pannel easily sometimes the pannels are hard to get off, and it would be good for you to have a ohm volt meter and no the safe way to operate around live voltage when testing.
Posted on Jul 28, 2009
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE referigerator Model # GSH25KGRE of 4 years old... I hear a constant click-click noise coming from the back/motor..and I suspect the temp in the freezer is slowly dying down..
The clicking behind the refrig , is comming from the main control board , behind the 8" X 10 " panel . The part number is WR55X10656 . The compressor relay , on the board has burnt . Yes , your freezer is thawing , due to the clicking .
Sep 23, 2009 | GE Refrigerators
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile Refrigerator clicking
Sounds like the main control board is bad . Check your warranty to see if board could still be covered .
Aug 08, 2009 | Refrigerators
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Feb 11, 2007 | GE GSH25KGRWW Side by Side Refrigerator
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
492 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
