Question about Samsung RS2630SH Side by Side Refrigerator
Water issue in fridge
We have a Samsung side-by-side. On the refridgerator side underneath the bottow draw there is an accumulation of water. I have to clean it out everyday or it starts overflowing. Any ideas where the water could be coming from and home to fix it
  • 833 Answers
Generally, this is condensation of humidity in the air. It is occurring after the defrost cycle. Check your door gaskets and clean or replace. Pull a 2 inch wide strip of typing paper through the gasket area to check for sealing. Oh, and if someone is 'window shopping', that's letting the humidity in.
Posted on Dec 19, 2007
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
Aug 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water accumulating in the bottm of refridgerator
HI, Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Let me know if I can assist you
Thanks
Vic
May 17, 2009 | Refrigerators
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Water Dispenser Not Working
the water spout on the dispensor unscrews this is a clog issue take it off and then run water becarful this does have a spray effect all over but it allows water to flow
also there is the problem of the water tube up the door has kinked when closed this is a big deal with front fridge water the ice dispensors tube goes up the back
May 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dcsv refridgerator
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Feb 13, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
81 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
