Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Cannot find music files on my LG KS360, transferred music on to it via usb cable on windows media player, and it sync's up, and depleted some of the memory from the memory card, but the files are nowhere to be found on my phone!!!
How do i load music on the ipod
iTunes is always the first choice for most of iPod users when it comes to transferring music from computer. It can help you transfer and backup files easily.
  1. Connect your iPod to PC via matched USB cable.
  2. Click the phone icon on the left corner of the interface. To manage your media files manually, you'd better go to "Options" under "Summary"tab, cancel "Automatically sync when this iPhone is connected" and check "Manually manage music and videos". Don't forget to click "Apply" when it's done.
  3. Import music into iTunes library from computer by clicking "File" and then "Add File to Library". Once transferred successfully, you can select the music icon on top to see all the songs.
  4. Click "Music" under "Settings" tab. Choose "Sync Music". You can either sync entire music library or selected playlists as you like. Then click "Sync" button at the bottom.
load-music-ipod-oxaxc0rwhkhzilrwacqreyis-5-0.png http://www.leawo.org/tutorial/transfer-music-to-iphone.html
Jan 25, 2016 | Audio Players & Recorders
I cannot find the drivers for my son's new Eclipse 180 series 4 gig mp3 player and I need help. Thank you!
Hi Mommychrista,
Thanks for the question ,
To connect this media player you don't require any additional drivers but you can use the inbuilt windows media player if you are using windows XP, VISTA or Windows 7.
However please note that you need windows media player version 7 or more to get this player connected to it.
What you need to do , is open windows media player and then connect this music player to a working USB port via the USB cable which comes along with this music player.
Then Windows Media player will prompt you with a setup screen asking you to name the MP3 player.
Once you have named your MP3 player, select Finish, and your Windows Media Player will open to the Sync tab.
Drag your music to the sync list (on the right of the screen) from the list on the left.
Once you have selected the music you wish to add to the player, press Sync.
Windows Media player will load the songs on to your MP3 player.
Once all the songs you have added are synced to the unit, and Windows Media Player says that is safe to disconnect your MP3 player, disconnect the device.
If your son has all his music files that he needs in one folder , then he can follow another method of simple copy and paste.
This works as follows :-
Connect the music player to the computer via the USB cable, connect this cable in a working USB slot and the player on the other end.
Then you will find a removable device being detected in your my computer, that removable drive is the memory of your music player in which you need to copy files.
Just right click on that icon of removable drive and select open and then you can copy the folder that you want to copy by right clicking on the folder and selecting copy and then come back to the removable drive , which you have opened and then select paste.
This will copy the complete folder to your music player's memory.
Then you can safely disconnect the music player via the USB cable and then you will find that the files are being shown in the music player , ready to play for you ...:)
Hope that helps ..:) In case you have any queries, feel free to let me know , your feedback would be appreciated.
Sep 12, 2011 | Mach Speed Eclipse 180 MP3 Player
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
How do i upload music from my pc to gigabeat 40gb i pod
To transfer music files to your gigabeat, simply connect it to the PC via USB cable. A gigabeat window will pop up on your screen and will direct you to WMP 11 (make sure to click the "Complete" button, or it will not take you to WMP 11). Once you're in WMP 11, assemble the list of music you wish to transfer and press "Sync". The program will automatically begin transferring data to your gigabeat.
Mar 01, 2011 | Toshiba Gigabeat F40 40 GB MP3 Player
How can you listen to music
First, you will have to transfer the music to the mp3 player. You can transfer music and pictures to your player using Windows Media Player. YOu can download it from here:
http://windows.microsoft.com/en-US/windows/products/windows-media-player
Once you have installed WMP, reboot and plug your mp3 player. By default, Windows Media Player automatically loads all the music and picture files stored in your My Music and My Pictures folders into the library. If you add new files to these folders, they will also be automatically added to the library. Then you will have to synchronize your mp3s player with WMP.
You can sync your music and pictures to your player using Windows Media Player. Simply connect your player to your computer using the supplied USB cable, set up sync, and you will be ready to sync your media library to the player. When you connect your player to the computer for the first time, Windows Media Player automatically selects the sync method (automatic or manual) that works best for your player. Automatic: If your player has sufficient storage space (at least 4GB of free space) and your entire media library can fit on your player, your entire media library will be automatically copied to your player as soon as you connect it to your computer. Manual: If your entire media library cannot fit on the player, then you will be prompted to manually select specific files or playlists that you want to transfer to your player.
Once you have transfer the music you want-unplug the player from the computer and that's it. If you have more doubts, you can download the manual from here:
http://download.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Feb 10, 2011 | Philips GOGEAR SA6045 MP3 Player
How can i get itunes to download on my phillips gogear 4gb?
Transfer music via Windows Media Player 10:
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
How to download music from computer to my philips gogear audio player
  1. Hook up your GoGear to the PC via the supplied USB cable.
  2. Plug your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Media Player 10.
    Note: Once the device is connected to the computer, all audio or radio playback will stop.
  5. Click "OK" to close the windows.
  6. Click the "Sync" tab.
  7. In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
  8. Click the check boxes next to any files you want to copy.
  9. In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
  10. Click the "Start Sync" button.
  11. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  12. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  13. Once the transfer is completed, close Windows Media Player.
  14. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Note! You cannot transfer pictures via Windows Explorer, for pictures you need to sync them using Windows Media Player.
  1. Connect your GoGear to the PC via the supplied USB cable.
  2. Connect your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Explorer.
  4. Drag and drop your music files into the Media/Music folder of your GoGear.
  5. Once your music has been transferred to your GoGear disconnect it from your computer and you are ready to listen to your music.
if this it was helpful rate my solution and vote me thanks
Jan 06, 2010 | Philips GoGear HDD1830 MP3 Player
HOW CAN I PUT MUSIC ON MY SONY NW-HD5 MP3 PLAYER......
1st ? yes you can store music to it and no you don't need any fancy software to transfer your music to the device just try these methods
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Mar 09, 2009 | Sony NW-HD5 MP3 Player
Lg k800
U have to follow this process.
Install Any USB drivers which are needed for your cable. Then connect your phone to the PC. Open Windows Media Player and click on the sync tab in Windows Media Player. Now on your phone hit MENU->Get It Now->Option 1 Music and Tones->6 Sync Music and the phone should show up under the devices in Windows Media Player. Now add the songs you want transfered to the sync side of Windows Media Player. Click Sync in Windows Media Player. and finally enjoy your music.
Oct 16, 2007 | LG KG800 Cellular Phone
GPX MW3337 sync problem
1- Check that your MP3 Player's File system is OK, you can do that using the DOS command (chkdsk /f). 2- Re-install your Windows Media Player 11. 3- Don't forget to update your system, too.
May 30, 2007 | GPX MW3337G
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
233 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
